foobar2000 Russian Community
10 сентября 2010, 15:52 *
Добро пожаловать, Гость. Пожалуйста, войдите или зарегистрируйтесь.
Вам не пришло письмо с кодом активации?
Посетите ресурсы сообщества — скачать foobar2000, FAQ, плагины для foobar2000, энциклопедия.
Войти
Новости: Jabber-конференция foobar2000 — JID: foobar2000@conference.jabber.ru
   Начало   Помощь Найти! Войти Регистрация
Страниц: 1 2 3 [4] 5 |   Вниз
  Печать
Автор Тема: Windows 7 Shell Integration v.0.2.9.1 (foo_w7shell.dll)  (Прочитано 22811 раз)
0 Пользователей и 1 гость смотрят эту тему.
meDveD
foo_v.i.p.
Репутация 56
Офлайн
моё сообщение там ->
Сайт пользователя
0.2.9.1:
     * Preferences page upgraded to be compatible with new SDK. Settings are now applied only on ‘Apply’ button click, no more ‘legacy page’ messages.
0.2.9.0:
     * Using new Foobar 1.0 SDK. Not compatible with older versions!
     * Album artwork configuration support
     * Hiding thumbnail progress indicator (and setting taskbar progress to indeterminate state) when playing stream of unknown length
0.2.8.1:
    * Taskbar progress indicator
    * Some changes on Settings page
0.2.8.0:
    * Options to enable Filp3D and/or Aero Peek back (a bit buggy thing, but people wanted it)
    * Some minor changes
0.2.7.1:
    * New setting: draw border around album art
      This may be useful when foobar is using transparent (layered) window and border is not drawn by system. There’s no bug with incorrect border size in alt-tab switcher in this mode, so turning transparency on is recommended for now.
    * Workaround for invalid pause button behavior in 7068
      In this build button messages are sent twice for some reason. This is definitely system bug, Windows Media Player is also working wrong.
0.2.7.0:
    * New feature: shows your playlists in jump list!
    * Added kinda of icons for play/preferences jump list entries
    * Some bugfixes
0.2.6.2:
    * Fixed crash on foobar update/reinstallation
    * Fixed thumbnail vertical flipping on builds after 7057
    * Improved stability when using with Columns UI
    * Other minor fixes
0.2.6.1:
    * Fixed compatibility issues when running on Vista/XP (previously crashed)
    * Added option to workaround built-in thumbnail toolbar in Columns UI 0.3.6.7
0.2.5.1:
    * New nice button icons
    * Thumbnails are loaded asynchronously
    * Play progress indicator
    * Settings page
    * Some refactoring
0.2.3.1:
    * Initial public release
Download:
http://wintense.com/plugins/foo_w7shell
автор плагина: pieceofsummer
« Последнее редактирование: 29 января 2010, 11:07 от meDveD » Записан
первое сообщение / продолжить топик
pieceofsummer
foo_user_novice
Репутация 6
Офлайн
Re: Windows 7 Shell Integration v.0.2.7.1 (foo_w7shell.dll) ответ №76 (06 июня 2009, 00:51)
Погоди. Ты пользуешься сервисом, который работает только в DefaultUI? А если ничего не отдано, то ищешь каверы сам по жёстко заданным маскам? Оп-па. А я сижу и думаю - почему всё так странно... Wink  А, оказывается, мой фубар тебе вообще ничего не отдаёт (в логах не отражено это), у меня же ColumnsUI.
Тогда огромная просьба - надо прикрутиться к ColumnsUI. Иначе смысл пропадает.
Я пользуюсь стандартным сервисом, он реализован в ядре фубара и работает в любом UI.
Жестко заданные маски для поиска, опять-таки, зашиты в самом фубаре, сам я ничего не ищу (я для этого слишком ленив Smiley )
В логах ничего и не обязано быть, стандартный сервис туда ничего не пишет.
У меня сейчас Columns UI, и с ним все прекрасно работает.
Записан
The Chief
foo_user_novice
Репутация 0
Офлайн
Re: Windows 7 Shell Integration v.0.2.7.1 (foo_w7shell.dll) ответ №77 (06 июня 2009, 01:06)
какие проблемы?
Так и пришлось делать. С мультикаверами (-front, -back, -inlay, -tray, -cd) сложнее. Приходится помнить, что фронт кавер надо сохранять без суффикса.
У альбум арт панели из columnsUI свои собственные маски. Настраиваемые. Отличные от стандартного UI.
Стандартный сервис работает не в любом UI. Иначе бы твой плагин подцеплял каверы типа cover-front.jpg (columnsUI цепляет их по дефолту), а он этого не делает. Кстати, можно в логи выводить, что получено от этого самого интерфейса?
« Последнее редактирование: 06 июня 2009, 01:15 от The Chief » Записан
pieceofsummer
foo_user_novice
Репутация 6
Офлайн
Re: Windows 7 Shell Integration v.0.2.7.1 (foo_w7shell.dll) ответ №78 (06 июня 2009, 01:15)
Если бы стандартный сервис не работал в любом UI, то мы бы сейчас вообще никаких картинок не видели в колумнсах.
Кстати, если колумнсу не указывать в настройках дополнительные маски, то по дефолту он читает ровно то же, что и встроенный. И никаких "cover-front", если их не указать явно.
Записан
The Chief
foo_user_novice
Репутация 0
Офлайн
Re: Windows 7 Shell Integration v.0.2.7.1 (foo_w7shell.dll) ответ №79 (06 июня 2009, 01:26)
Да и бог с вами. Не хотите делать действительно универсально - так и скажите.
Записан
pieceofsummer
foo_user_novice
Репутация 6
Офлайн
Re: Windows 7 Shell Integration v.0.2.7.1 (foo_w7shell.dll) ответ №80 (06 июня 2009, 02:46)
Если найду способ зацепиться к CUI-шной читалке обложек - сделаю. Если не найду - не сделаю.
Во всяком случае, еще одну страницу конфигурации путей для обложек я точно делать не собираюсь.
Записан
Gooff
foo_user_novice
Репутация 0
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №81 (26 сентября 2009, 00:02)
(К разработчику) Может попробуете добавить визуализацию, наложенную на альбом-арт?
Записан
White-Zayac
foo_user_novice
Репутация 0
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №82 (01 октября 2009, 11:19)
у меня проблемка, когда запускал прогу по обычному при выходе выдавала какие то ошибки и при следующем включении не сохранялись плейлисты, при запуске от администратора эта проблема решилась, но теперь в маленьком окошке пропали кнопки управления и нельзя перетаскивать музыку из обычного проводника в список песен фубара   Sad Sad Sad хелп
Записан
pieceofsummer
foo_user_novice
Репутация 6
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №83 (01 октября 2009, 11:36)
2White-Zayac
В режиме администратора взаимодействие с explorer-ом не работает, и как следствие - никаких кнопочек и drag-n-drop (на самом деле, кнопочки должны были бы быть, но в винде до сих пор есть баг с хождением сообщений в админские процессы).
Так что проще решить свои ошибки с сохранением.
2Gooff
Даже пробовать не буду. Есть куда более интересные способы потратить время и ресурсы, кроме как прикручивать бесполезные свистелки.
Записан
Zin-Uru
foo_v.i.p.
Репутация 41
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №84 (07 октября 2009, 13:55)
Очень хороший плагин, спасибо! Но иногда пропадают кнопочки (например, при работе с некоторыми полноэкранными приложениями, когда Фубар в свернутом состоянии). Остаются пустые квадратики. При щелчке по какому-либо из них кнопки снова появляются. Со стандартными UI кнопками такого нет.
Записан
White-Zayac
foo_user_novice
Репутация 0
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №85 (10 октября 2009, 07:42)
2pieceofsummer
и как же решить эту проблему с сохранением не подскажете???
Записан
acmodeu
foo_user_novice
Репутация 1
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №86 (30 октября 2009, 13:02)
Заметил такую особенность - если в папке нет обложки, то плагин показывает свое встроенное изображение, если же обложку добавить, то плагин все равно не показывает ее пока не перезапустишь фубар. nu Мне понятно, что нельзя проверять наличие обложки каждую секунду, но хотя бы на каждой песне, даже если альбом не меняется (или как тут реализована проверка).
Записан
Elixer
foo_user_novice
Репутация 3
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №87 (30 октября 2009, 13:13)
На следующем треке он обновляет обложку.
Записан
acmodeu
foo_user_novice
Репутация 1
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №88 (30 октября 2009, 14:21)
Только что проверил, даже конфиг скинул. Если альбом не меняется, то не обновляет.
Записан
Elixer
foo_user_novice
Репутация 3
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №89 (30 октября 2009, 15:08)
И вправду не обновляет. Сейчас посмотрел поподробней, это оказываеться "foo_covers" обновляет после каждого трека и соответственно "foo_w7shell" тоже подхватывает.
Записан
evil
foo_v.i.p.
Репутация 58
Офлайн
Respect: Грандмаста
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №90 (20 ноября 2009, 21:46)
В версии 1.0 beta 1 не работает: отображается стандартное окошко.
Записан
meDveD
foo_v.i.p.
Репутация 56
Офлайн
Сайт пользователя
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №91 (21 ноября 2009, 12:22)
evil
это не так.
Записан
evil
foo_v.i.p.
Репутация 58
Офлайн
Respect: Грандмаста
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №92 (21 ноября 2009, 14:29)
Win 7 7600 64bit?
Записан
meDveD
foo_v.i.p.
Репутация 56
Офлайн
Сайт пользователя
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №93 (21 ноября 2009, 14:52)
Win 7 7600 64bit?
значит только на x86 всё нормально.
Записан
SpirtRoyal
foo_user_advanced
Репутация 3
Офлайн
Сайт пользователя
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №94 (21 ноября 2009, 15:20)
evil,
Win 7 7600 64bit?
все путем у меня на 7 7600 64
Записан
Zin-Uru
foo_v.i.p.
Репутация 41
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №95 (21 ноября 2009, 15:44)
Подтверждаю! Новый 1.0 бета 1, Windows 7 7600 х64 - компонент работает как и раньше.
Записан
evil
foo_v.i.p.
Репутация 58
Офлайн
Respect: Грандмаста
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №96 (21 ноября 2009, 16:08)
Да, работает. Отменяю претензию.  Embarrassed
Записан
evil
foo_v.i.p.
Репутация 58
Офлайн
Respect: Грандмаста
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №97 (30 ноября 2009, 22:36)
Интересно, чего не нравится Online troubleshooter-у?
Код:
foo_w7shell.dll : Windows 7 integration 0.2.8.1
Reason: Component problematic under foobar2000 versions older than 1.0 beta 1.
Записан
_DRON_
Разработчик
foo_v.i.p.
Репутация 64
Офлайн
Сайт пользователя
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №98 (30 ноября 2009, 23:01)
2evil
Common third party component problem with cross-thread SendMessage() inside a global callback has been worked-around on core side. While this in theory still is a component bug, the nature of the problem is too obscure for most component developers to know without studying MSDN in detail; additionally you have to be very careful regarding what third party code that you call does. Multiple components that were problematic in 0.9.x versions due to this problem are now entirely safe to use. This includes foo_w7shell and various instant messenger interaction components. The troubleshooter will be updated accordingly.
Записан
diez
foo_user_novice
Репутация 0
Офлайн
Re: Windows 7 Shell Integration v.0.2.8.1 (foo_w7shell.dll) ответ №99 (11 декабря 2009, 16:48)
как часики) как в общем то и весь фубар)
Записан
Tepple
foo_user_master
Репутация 15
Офлайн
Re: Сборка от Alex Realist all-in-one [18.03.2010] ответ №100 (28 марта 2010, 23:07)
Видите разницу? Не знаю, от чего это зависит, но то так то сяк..((
Записан
"Мы можем отправиться куда угодно.."~~~Ластик
Страниц: 1 2 3 [4] 5 |   Вверх
  Печать
Перейти в:
Red*Army|Sp1ke
RSS форума | WAP-версия форума | Версия для печати
© 2006—2009 Русское сообщество foobar2000. Поддержка проекта — Спайк. Движок форума — SMF. Лицензия — Creative Commons.
Google был здесь 08 сентября 2010, 14:02
