Список разделов › foobar2000 › Секреты foobar2000
//1 Column
$puts(1-Column-Theme,1)
$puts(1C,$select($get(1-Column-Theme),$rgb(53,62,120),$rgb(192,192,192),$rgb(164,164,164),$rgb(255,0,0)))
//2 Column
$puts(2-Column-Theme,1)
$puts(2C,$select($get(2-Column-Theme),$rgb(34,117,200),$rgb(192,192,192),$rgb(164,164,164),$rgb(255,0,0)))
//3 Column
$puts(3-Column-Theme,1)
$puts(3C,$select($get(3-Column-Theme),$rgb(37,126,216),$rgb(192,192,192),$rgb(164,164,164),$rgb(255,0,0)))
//4 Column
$puts(4-Column-Theme,1)
$puts(4C,$select($get(4-Column-Theme),$rgb(87,155,226),$rgb(192,192,192),$rgb(164,164,164),$rgb(255,0,0)))
$if(%isplaying%,$get(1C)Mode: BB7A02%_trackinfo_mode%$char(10),)
$if(%isplaying%, $transition($repeat(–,15),$rgb(170,205,240),$rgb(34,117,200)) $rgb(53,62,120)♪ $upper(Song info) ♪ $transition($repeat(–,15),$rgb(34,117,200),$rgb(170,205,240))$char(10),)
$if(%artist%,$get(1C)Artist: $get(2C)$caps(%artist%)$char(10),)
$if(%isplaying%,$get(1C)Album: $get(2C)$replace($if(%album%,%album%,%directoryname%),_, , ,)$char(10),)
$if(%title%,$get(1C)Title: $get(2C)$replace($caps(%title%),_, , ,)$char(10),)
$if(%date%,$get(1C)Date: $get(2C)%date%$char(10),)
$if(%genre%,$get(1C)Genre: $get(2C)%genre%$char(10),)
$if(%tracknumber%,$get(1C)Track Number: $get(2C)%tracknumber%$char(10),)
$if(%length%,$get(1C)Length: $get(2C)%length%$char(10),)
$if(%isplaying%, $transition($repeat(–,15),$rgb(170,205,240),$rgb(34,117,200)) $rgb(53,62,120)● $upper(File info) ● $transition($repeat(–,15),$rgb(34,117,200),$rgb(170,205,240))$char(10),)
$if(%isplaying%,$get(3C)Codec: $get(4C)$if(%codec%,%codec%,$ext(%path%))$char(10),)
$if(%isplaying%,$get(3C)Bitrate: $get(4C)%bitrate% kbps$char(10),)
$if(%isplaying%,$get(3C)Channels: $get(4C)$caps(%channels%)$char(10),)
$if(%isplaying%,$get(3C)Encoding type: $get(4C)$caps(%__encoding%)$char(10),)
$if(%isplaying%,$get(3C)Samplerate: $get(4C)%samplerate% Hz$char(10),)
$if(%isplaying%,$get(3C)ReplayGain: $get(4C)AG: $get(2C)%__replaygain_album_gain% $get(4C)TG: $get(2C)%__replaygain_track_gain%$char(10),)
$if(%__mp3_stereo_mode%,$get(3C)Stereo Mode: $get(4C)$caps(%__mp3_stereo_mode%)$char(10),)
$if(%__tagtype%,$get(3C)Tagtype: $get(4C)$replace($caps(%__tagtype%),'|',$get(4C) & $get(4C))$char(10),)
$puts(Filesize,$div(%_filesize%,1048576).$num($div($mul($mod(%_filesize%,1048576),100),1048576),2))
$if(%isplaying%,$get(3C)Filesize: $get(4C)$get(Filesize) MB$char(10))
$if(%isplaying%, $transition($repeat(–,13),$rgb(170,205,240),$rgb(34,117,200)) $rgb(53,62,120)❙❙ $upper(Progress bar) ❙❙ $transition($repeat(–,13),$rgb(34,117,200),$rgb(170,205,240))$char(10),)
//$if(%isplaying%,$progress2(%playback_time_seconds%,%length_seconds%,48,737373'❙❙',D7D7D7'❙❙')$char(10),)
$puts(1,$transition($repeat('❙❙',$muldiv(48,%playback_time_seconds%,%length_seconds%)),3FAD7E,297454))
$puts(2,$transition($repeat('❙❙',$sub(48,$muldiv(48,%playback_time_seconds%,%length_seconds%))),$rgb(166,213,121),$rgb(195,233,152)))
$if(%isplaying%,$get(1)$get(2)$char(10),)
//1 Column
//2 Column
//3 Column
//4 Column
$puts(Line1,$transition($repeat(‒,16),$rgb(170,205,240),$rgb(34,117,200)))
$puts(Line2,$transition($repeat(‒,16),$rgb(34,117,200),$rgb(170,205,240)))
$if(%isplaying%,$get(2C)〚Filesize〛$tab()$get(Line1)$get(Line2)A8564A'〚'
$ifgreater(%_filesize%,30000000,▁ ▂ ▃ ▄ ▅ ▆ ▇ █,
$ifgreater(%_filesize%,26000000,▁ ▂ ▃ ▄ ▅ ▆ ▇$rgb(124,179,226) █,
$ifgreater(%_filesize%,22000000,▁ ▂ ▃ ▄ ▅ ▆$rgb(124,179,226) ▇ █,
$ifgreater(%_filesize%,18000000,▁ ▂ ▃ ▄ ▅$rgb(124,179,226) ▆ ▇ █,
$ifgreater(%_filesize%,14000000,▁ ▂ ▃ ▄$rgb(124,179,226) ▅ ▆ ▇ █,
$ifgreater(%_filesize%,10000000,▁ ▂ ▃$rgb(124,179,226) ▄ ▅ ▆ ▇ █,
$ifgreater(%_filesize%,6000000,▁ ▂$rgb(124,179,226) ▃ ▄ ▅ ▆ ▇ █,
$ifgreater(%_filesize%,2000000,▁$rgb(124,179,226) ▂ ▃ ▄ ▅ ▆ ▇ █,
))))))))A8564A'〛'$char(10),)
$if(%isplaying%,$get(2C)〚Bitrate Bar〛$tab()$get(Line1)$get(Line2)
$puts(low,E4A463)
$puts(med,A8564A)
$puts(high,$rgb(53,62,120))
$puts(Choose,$if($strcmp($info(bitrate),256),$get(med),$ifgreater($info(bitrate),256,$get(high),$get(low))))
$puts(3,$repeat('❙',$muldiv(26,$info(bitrate),1411)))
$puts(4,$repeat('·',$sub(26,$muldiv(26,$info(bitrate),1411))))
$if(%isplaying%,A8564A'〚'$get(Choose)$get(3)$get(4)A8564A'〛'$char(10),))
$if(%isplaying%,$get(4C)
$puts(low,E4A463)
$puts(med,A8564A)
$puts(Choose2,$if($strcmp($info(samplerate),44100),$get(med),$ifgreater($info(samplerate),44100,$get(high),$get(low))))
$puts(3,$repeat('❙',$muldiv(26,$info(samplerate),96000)))
$puts(4,$repeat('·',$sub(26,$muldiv(26,$info(samplerate),96000))))
$get(2C)〚Samplerate Bar〛$tab()$get(Line1)$get(Line2)$get(Choose2)'〚'$get(Choose2)$get(3)$get(4)$get(Choose2)'〛'$char(10),)
$if(%isplaying%,$get(2C)〚Channels〛$tab()$get(Line1)$get(Line2)$tab()A8564A'〚'$if($stricmp(%channels%,mono),①,$if($stricmp(%channels%,stereo),②,⑤.①))'〛'$char(10),)
$puts(Cloud,E2E2E2)
$puts(Water1,
$repeat( ,34)00D7D7☼$char(10)
$get(Cloud)$repeat( ,1)☁$char(10)
$rgb(2,122,187)$repeat(♒,20)$char(10))
$puts(Water2,
$repeat( ,35)00D7D7☼$char(10)
$get(Cloud)$repeat( ,9)☁$char(10)
$puts(Water3,
$get(Cloud)$repeat( ,19)☁$char(10)
$puts(Water4,
$repeat( ,36)00D7D7☼$char(10)
$get(Cloud)$repeat( ,26)☁$char(10)
$puts(Water5,
$get(Cloud)$repeat( ,33)☁$char(10)
$puts(Water6,
$get(Cloud)$repeat( ,40)☁$char(10)
$puts(Water7,
$get(Cloud)$repeat( ,47)☁$char(10)
$puts(Water8,
$get(Cloud)$repeat( ,54)☁$char(10)
$puts(Water9,
$get(Cloud)$repeat( ,61)☁$char(10)
$puts(Water0,
$get(Cloud)$repeat( ,68)☁$char(10)
$if(%isplaying%,
$if($strcmp($right(%playback_time_seconds%,1),1),$get(Water1),
$if($strcmp($right(%playback_time_seconds%,1),2),$get(Water2),
$if($strcmp($right(%playback_time_seconds%,1),3),$get(Water3),
$if($strcmp($right(%playback_time_seconds%,1),4),$get(Water4),
$if($strcmp($right(%playback_time_seconds%,1),5),$get(Water5),
$if($strcmp($right(%playback_time_seconds%,1),6),$get(Water6),
$if($strcmp($right(%playback_time_seconds%,1),7),$get(Water7),
$if($strcmp($right(%playback_time_seconds%,1),8),$get(Water8),
$if($strcmp($right(%playback_time_seconds%,1),9),$get(Water9),
$if($strcmp($right(%playback_time_seconds%,1),0),$get(Water0),
// BG
$alignabs(,middle)$font(Arial,10,,100-100-100)
$transition(TIME TIME TIME TIME,$rgb(100,100,100),$rgb(130,130,255))$char(10)
$alignabs(right,middle)$font(Arial,10,,100-100-100)
$transition(CODEC CODEC CODEC,$rgb(130,130,255),$rgb(100,100,100))$char(10)
$alignabs(right,middle)$font(Tahoma,7,shadow,150-150-255)
$if(%isplaying%,
$if2(%codec% ,)$if2($char(40)$caps($info(encoding))$char(41),)$char(10)
$if2($if($info(mp3_stereo_mode),$caps($info(mp3_stereo_mode)),$info(channels)),)$char(10)
$if2(%bitrate%kbps ,)$if($strcmp($upper($info(codec)),MP3),$if2($info(extrainfo),CBR),)$char(10)
$if2($div(%samplerate%,1000)$ifequal($div($mod(%samplerate%,1000),100),0,,.$div($mod(%samplerate%,1000),100))KHz,)$char(10)
$char(10)
$get(info)$div(1411,%__bitrate%).$substr($muldiv(1411,100,%__bitrate%),2,3):1 '('$get(info)$muldiv(%__bitrate%,100,1411)$get(anno)'%)'$char(10)
$alignabs(,middle)$font(Impact,32,shadow,150-150-255)
$if2(%_time_elapsed%,)
$font(Haettenschweiler,30,,)
$ifgreater($calcwidth(%artist% - %title%),%_width%
,$font(,22,shadow,)
,$font(,30,shadow,)
$align(center,middle)$rgb(150,150,255)
$if(%artist%,%artist% - ,)$if2(%title%,)
//Track Info Panel Formatted Strings v.1.1 by iv_nik (10.04.2006)
//Based on Track Info Panel Formatted Strings v.1.0 from Mr. FreeZZZ (08.02.2005 16:05)
// =============CONFIGURATION==============
// Language settings
// 1 - Russian, 2 - English
$puts(language,1)
//Color scheme settings
// 0 - Black (set the R-0,G-0,B-0 background color)
// 1 - White (set the R-255,G-255,B-255 background color)
// 2 - Creme (set the R-252,G-252,B-248 background color)
$puts(color_scheme,1)
//Showing strings
// 1- Show, 0 - Hide
//Song info part
$puts(s0,1)
//Artist
$puts(s1,1)
//Song
$puts(s2,1)
//Album
$puts(s3,1)
//Number of track
$puts(s4,1)
//Year
$puts(s5,1)
//Genre
$puts(s6,1)
//Rating
$puts(s7,0)
//Comment
$puts(s8,0)
//Show tech part
$puts(t0,1)
//Codec
$puts(t1,1)
//Bitrate
$puts(t2,1)
//Samplerate
$puts(t3,0)
//Channels
$puts(t4,0)
//Play count
$puts(t5,0)
//Last play date
$puts(t6,0)
//Time
$puts(t7,0)
//FileSize
$puts(t8,1)
//Last.FM
$puts(t9,1)
//Progress bar
$puts(t10,0)
// _CODE_SECTION_===========================
// _BLACK
$if($strcmp(0,$get(color_scheme)),
$puts(error_text_color,808080)
$puts(static_text_color,ffff80)
$puts(dynamic_text_color,ffffff)
$puts(section_color,00ff00)
$puts(plus_time_color,$blend($rgb(0,255,0),$rgb(255,255,0),%_time_elapsed%,%_time_total%))
$puts(minus_time_color,$blend($rgb(255,255,0),$rgb(0,255,0),%_time_elapsed%,%_time_total%))
// _WHITE
$if($strcmp(1,$get(color_scheme)),
$puts(error_text_color,c0c0c0)
$puts(static_text_color,000000)
$puts(dynamic_text_color,400080)
$puts(section_color,804000)
$puts(plus_time_color,$blend($rgb(0,128,0),$rgb(255,0,0),%_time_elapsed%,%_time_total%))
$puts(minus_time_color,$blend($rgb(255,0,0),$rgb(0,128,0),%_time_elapsed%,%_time_total%))
// _CREME
$if($strcmp(2,$get(color_scheme)),
$puts(static_text_color,408080)
$puts(dynamic_text_color,c08000)
$puts(section_color,404080)
// Russian strings
$if($strcmp(1,$get(language)),
$puts(Song_Info,Информация о треке:)
$puts(Track_No_Present,Нет трека)
$puts(Artist,Исполнитель: )
$puts(Artist_Present,Неизвестный артист)
$puts(Title,Песня: )
$puts(Album,Альбом: )
$puts(Album_Present,Нет альбома)
$puts(Track,Номер: )
$puts(Is_Single,Сингл)
$puts(Date,Год: )
$puts(No_Date,Без даты)
$puts(Genre,Жанр: )
$puts(No_Genre,Неизвестно)
$puts(Rating,Оценка: )
$puts(Comment,Комментарий: )
$puts(Not_Rated,Без оценки)
$puts(No_Comment,Без комментария)
$puts(Technical,Техническая информация: )
$puts(Codec,Кодек: )
$puts(Bitrate,Битрейт: )
$puts(kbps, Кб/c)
$puts(Samplerate,Частота сэмплов: )
$puts(Hz, кГц)
$puts(Channels,Каналы: )
$puts(played,Эта песня играла )
$puts(times, раз'('а')')
$puts(Last,Последний раз: )
$puts(at,в )
$puts(Never, Никогда)
$puts(Time,Время: )
$puts(total,всего )
$puts(filesize,Размер файла: )
$puts(lastfm,Last.FM: )
$puts(submitted,Отправлено)
$puts(pending,Ожидание...),)
// English strings
$if($strcmp(2,$get(language)),
$puts(Song_Info,Song Info:)
$puts(Track_No_Present,No Track)
$puts(Artist,Artist: )
$puts(Artist_Present,Unknown Artist)
$puts(Title,Title: )
$puts(Album,Album: )
$puts(Album_Present,Unknown Album)
$puts(Track,Track: )
$puts(Is_Single,Single)
$puts(Date,Date: )
$puts(No_Date,Unknown Date)
$puts(Genre,Genre: )
$puts(No_Genre,No Genre)
$puts(Rating,Rating: )
$puts(Comment,Comment: )
$puts(Not_Rated,No Rated)
$puts(No_Comment,No comment)
$puts(Technical,Technical Info: )
$puts(Codec,Codec: )
$puts(Bitrate,Bitrate: )
$puts(kbps, kbps)
$puts(Samplerate,Samplerate: )
$puts(Hz, kHz)
$puts(Channels,Channels: )
$puts(played,This song was played )
$puts(times, times)
$puts(Last,Last played: )
$puts(at,at )
$puts(Never, Never)
$puts(Time,Time: )
$puts(total,total )
$puts(filesize,File Size: )
$puts(lastfm,Last.FM Status: )
$puts(submitted,Submitted)
$puts(pending,Pending...)
$if($strcmp(1,$get(s0)),
$get(section_color)$get(Song_Info)$char(10)
$if(%_trackinfo_notrack%,$get(error_text_color)$get(Track_No_Present)$char(10),
$if($strcmp(1,$get(s1)),
$get(static_text_color)$get(Artist)
$get(dynamic_text_color)
$if2($caps(%artist%),$get(error_text_color)$get(Artist_Present))
$char(10)
$if($strcmp(1,$get(s2)),
$get(static_text_color)$get(Title)
$if2($caps(%title%),%_filename%)
$char(10)
$if($strcmp(1,$get(s3)),
$get(static_text_color)$get(Album)
$if2($caps(%album%),$get(error_text_color)$get(Album_Present))
$char(10)
$if($strcmp(1,$get(s4)),
$get(static_text_color)$get(Track)
$if2(%tracknumber%,$get(Is_Single))
$char(10)
$if($strcmp(1,$get(s5)),
$get(static_text_color)$get(Date)
$if2(%date%,$get(error_text_color)$get(No_Date))
$char(10)
$if($strcmp(1,$get(s6)),
$get(static_text_color)$get(Genre)
$if2(%Genre%,$get(error_text_color)$get(No_Genre))
$char(10)
$if($strcmp(1,$get(s7)),
$get(static_text_color)$get(Rating)
$if2(%Rating%,$get(error_text_color)$get(Not_Rated))
$char(10)
$if($strcmp(1,$get(s8)),
$get(static_text_color)$get(Comment)
$if2(%Comment%,$get(error_text_color)$get(No_Comment))
$char(10)
$char(10)
$if($strcmp(1,$get(t0)),
$get(section_color)$get(Technical)$char(10)
$if($strcmp(1,$get(t1)),
$get(static_text_color)$get(Codec)$get(dynamic_text_color)$codec()$if($stricmp($codec(),MP3),[ %__extrainfo%])
$char(10)
$if($strcmp(1,$get(t2)),
$get(static_text_color)$get(Bitrate)$get(dynamic_text_color)$if(%__extrainfo%,~,)%__bitrate%$get(static_text_color)$get(kbps)
$char(10)
$if($strcmp(1,$get(t3)),
$get(static_text_color)$get(Samplerate)$get(dynamic_text_color)$div(%__Samplerate%,1000)','$cut($mod(%__Samplerate%,1000),1)$get(static_text_color)$get(Hz)
$char(10)
$if($strcmp(1,$get(t4)),
$get(static_text_color)$get(Channels)
$get(dynamic_text_color)%__channels% $if(%__mp3_stereo_mode%, '('%__mp3_stereo_mode%')',)
$char(10)
$if($strcmp(1,$get(t5)),
$get(static_text_color)$get(played)$get(dynamic_text_color)$if(%play_counter%,%play_counter%,0)$get(static_text_color)$get(times)
$char(10)
$if($strcmp(1,$get(t6)),
$get(static_text_color)$get(Last)$get(dynamic_text_color)$if(%play_date%,%play_date% $get(static_text_color)$get(at)$get(dynamic_text_color)%play_time%,$get(Never))
$char(10)
$if($strcmp(1,$get(t7)),
$get(static_text_color)$get(Time)
$if(%_isplaying%,$get(plus_time_color)%_time_elapsed% $get(static_text_color)| $get(dynamic_text_color)%_time_total% $get(static_text_color)$get(static_text_color)| $get(minus_time_color)%_time_remaining%$get(static_text_color),$get(dynamic_text_color)%_length%)
$char(10)
$if($strcmp(1,$get(t8)),
$get(static_text_color)$get(filesize)$get(dynamic_text_color)$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2)$get(static_text_color)' MB'
$char(10)
$if($strcmp(1,$get(t9)),
$get(static_text_color)$get(lastfm)$get(dynamic_text_color)$if(%_isplaying%,
$ifgreater(%_time_elapsed_seconds%,240,$get(submitted),
$ifgreater(%_time_elapsed_seconds%,$div(%_time_total_seconds%,2),$get(submitted),$get(pending))))
$char(10)
$char(10)
$if($strcmp(1,$get(t10)),
$progress(%_time_elapsed_seconds%, %_time_total_seconds%, 25,400080'|',9a9a9a'-'),)
А где этот код??? Нужна только эта функция...включая Last.FM Status
Чуть ниже в окошке код :)0100100010011:А где этот код??? Нужна только эта функция...
$char(10)
а какой он там? скрин дай.0100100010011:и еще...можно ли такой же прогресс бар как у клиента last.fm?
Кто знает?
[%genre%][ ◉ %style%]$tab()$if(%isplaying%,$tab()[$max(0,$left($muldiv(%playback_time_seconds%,1000,%length_seconds%),$sub($len($muldiv(%playback_time_seconds%,1000,%length_seconds%)),1)))'.'$right($muldiv(%playback_time_seconds%,1000,%length_seconds%),1)'%']' ◉ ')[%length%][ - %playback_time_remaining% =][ %playback_time%][ ◉ x%play_count%]$char(10)
$tab()$rgb(255,0,0)[%artist%]$tab()$char(10)
$tab()$rgb(255,255,0)[%album%]$tab()$char(10)
$tab()$rgb(255,255,0)[$if2(%date%,%year%)]$tab()$char(10)
$tab()$rgb(0,255,0)[[%disc%.]%tracknumber%[/%trackcount%]: ][$meta(title,0)]$tab()$char(10)
$tab()$rgb(0,0,255)[%remix%]$tab()$char(10)
$char(10)
$tab()
$select(%rating%,
$rgb(0,0,255)★,
$rgb(0,0,255)★★,
$rgb(0,255,0)★★★,
$rgb(0,255,0)★★★★,
$rgb(255,255,0)★★★★★,
$rgb(255,255,0)★★★★★★,
$rgb(255,0,0)★★★★★★★,
$rgb(255,0,0)★★★★★★★★,
$rgb(255,255,255)★★★★★★★★★)
$tab()$char(10)
$tab()[%composer%]$tab()$char(10)
$tab()$if3(G: %game%,M: %movie%,)$tab()$char(10)
$if(%_isplaying%,$ifgreater(%_time_elapsed_seconds%,240,'*', $ifgreater(%_time_elapsed_seconds%,$div(%_time_total_seconds%,2),'*',)))
[$if2(%__replaygain_track_gain%,No) TG ◉ $if2(%__replaygain_album_gain%,No) AG][ ◉ $if(%lyrics%,L)]$tab()[[%__bitrate_dynamic%◈]%__bitrate%[◈%__bitrate_nominal%] kbps][ ◉ %__samplerate% hz ◉ %__channels% ch][ ◉ %__codec%]
$if(%isplaying%,
$char(10)
$tab()
$select(%rating%,
$rgb(0,0,255)★,
$rgb(0,0,255)★★,
$rgb(0,255,0)★★★,
$rgb(0,255,0)★★★★,
$tab()$char(10)
$tab()[%genre%][ ◉ %style%]$tab()$char(10)
$char(10)
$tab()[$max(0,$left($muldiv(%playback_time_seconds%,1000,%length_seconds%),$sub($len($muldiv(%playback_time_seconds%,1000,%length_seconds%)),1)))'.'$right($muldiv(%playback_time_seconds%,1000,%length_seconds%),1)'%']' ◉ ')[%length%][ - %playback_time_remaining% =][ %playback_time%][ ◉ x%play_count%]$tab()$char(10)
$tab()[$if2(%__replaygain_track_gain%,No) TG ◉ $if2(%__replaygain_album_gain%,No) AG][ ◉ $if(%lyrics%,L)]$tab()$char(10)
$tab()[[%__bitrate_dynamic%◈]%__bitrate%[◈%__bitrate_nominal%] kbps][ ◉ %__samplerate% hz ◉ %__channels% ch][ ◉ %__codec%]$tab()
$puts(d,32)
$puts(h,22)
$puts(m,30)
$puts(s,0)
$puts(day,$num($substr(%cwb_systemdatetime%,9,10),1))
$puts(hour,$num($substr(%cwb_systemdatetime%,12,13),1))
$puts(minute,$num($substr(%cwb_systemdatetime%,15,16),1))
$puts(second,$num($substr(%cwb_systemdatetime%,18,20),1))
$puts(time,$add($mul($get(day),86400),$mul($get(hour),3600),$mul($get(minute),60),$get(second)))
$puts(t,$add($mul($get(d),86400),$mul($get(h),3600),$mul($get(m),60),$get(s)))
$puts(dx,$sub($get(t),$get(time)))
$puts(hx,$num($div($get(dx),3600),2))
$puts(mx,$num($div($mod($get(dx),3600),60),2))
$puts(sx,$num($mod($mod($get(dx),3600),60),2))
$tab()$ifgreater($get(dx),0,$get(hx):$get(mx):$get(sx),00:00:00)$tab()$char(10)
//Поиск слов в тегах
$puts(lyr,[$if3(%unsyncedlyrics%,%unsynced lyrics%,%lyrics%,%lyric%)])
//Удаление "мусора" в окончании строк (возврат каретки) и перевода строки
$puts(lyr,$replace($get(lyr),$char(13)$char(10),' '))
//Длина бегущей строки
$puts(bsl,30)
//Позиция в тексте
$puts(ptxt,$max(0,$muldiv(%playback_time_seconds%,$sub($len($get(lyr)),$get(bsl)),%length_seconds%)))
//Вывод
$get(t2)'Lyrics: '$get(t3)$if3(...$substr($get(lyr),$get(ptxt),$add($get(ptxt),$get(bsl)))...,'найти и добавить!')$char(10)
У меня в скрипте этот символ вместе с переводом каретки убираетDeskoul:Перевод строки в коментариях выдаёт какойто неопознаный символ, это можно както побороть? Хелп!!! :-[
$replace($get(lyr),$char(13),)
