http://lame.sourceforge.net/
-S --noreplaygain -V 0 --vbr-new - %d
В хелпе рекомендуют -q 2. По дефолту там -q5.Merak писал(а):И кста, лучше все-таки "-q 0" ставить... об этом в help-е чотко сказано!
Merak писал(а):тут дело не в битрейте. почитайте wiki
Скорее "сомнительный (маловероятный) выигрыш в звучании""doubtful audible benefit" - сомнительно-слышимое приемуществ
-q 0..9 algorithm quality selection
Bitrate is of course the main influence on quality. The higher the bitrate, the higher the quality. But for a given bitrate, we have a choice of algorithms to determine the best scalefactors and Huffman encoding (noise shaping).
-q 0: use slowest & best possible version of all algorithms. -q 0 and -q 1 are slow and may not produce significantly higher quality.
-q 2: recommended. Same as -h.
-q 5: default value. Good speed, reasonable quality.
-q 7: same as -f. Very fast, ok quality. (psycho acoustics are used for pre-echo & M/S, but no noise shaping is done.
-q 9: disables almost all algorithms including psy-model. poor quality.
чиво-чиво?Booroondook писал(а):Интересно, с какими параметрами -q жмётся музыка в сети!?
для чего?Mr.Merak писал(а):А лучше, скачать лосслесс и перегнать в огг
. For ALL other sources (CD, Vinyl, DVD, SBD, CABLE, LINE, etc.):
You must use either:
- LAME 3.97 (final version!) with preset V2 and VBRNEW
("-V2 --vbr-new") or
- LAME 3.90.3 (modified version preferred) with preset APS
("--alt-preset standard").
For both LAME versions additional switches which would affect
the mp3 quality are forbidden, especially no minimum or maximum
bitrate limits.
