блин, мне и добавить нечего
mgz писал(а):Когда же сменились колонки, звукашка - послушал... и эти диски более никогда не были прослушаны
вот это именно та причина, по которой стоит качать lossless вместо мр3, даже если пока не слышишь разницы.
а тупо погнать :)G-Man писал(а):Встречный вопрос: зачем?
zotik писал(а):"C:\Program Files\foobar2000\Encoders\lame-3.98.3\lame.bat"
1 out of 1 tracks converted with major problems.
Source: "M:\MUSIC\_NEW\Persefone - Shin-Ken (2009)\01 - The Ground Book (intro).wav"
An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "M:\MUSIC\_NEW\Persefone - Shin-Ken (2009)\01 - The Ground Book (intro).mp3"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "C:\Program Files\foobar2000\encoders\lame.exe" -V0 -q 0 -p "01 - The Ground Book (intro).mp3"
Working folder: M:\MUSIC\_NEW\Persefone - Shin-Ken (2009)\
Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
M:\MUSIC\_NEW\Persefone - Shin-Ken (2009)>"C:\Program Files\foobar2000\encoders\lame.exe" -V0 -q 0 -p "01 - The Ground Book (intro).wav"
LAME 3.98.3 32bits (http://www.mp3dev.org/)
CPU features: MMX (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 19383 Hz - 19916 Hz
Encoding 01 - The Ground Book (intro).wav
to 01 - The Ground Book (intro).wav.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III VBR(q=0)
Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
3041/3041 (100%)| 0:03/ 0:03| 0:03/ 0:03| 23.221x| 0:00
32 [ 2] *
40 [ 0]
48 [ 0]
56 [ 0]
64 [ 0]
80 [ 0]
96 [ 0]
112 [ 0]
128 [ 0]
160 [ 1] %
192 [ 375] %%%%%%%%%%%%*
224 [2094] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%****
256 [ 534] %%%%%%%%%%%%%%%%**
320 [ 35] %*
kbps LR MS % long switch short %
226.6 92.5 7.5 99.0 0.6 0.4
Writing LAME Tag...done
ReplayGain: +1.0dB
SPV писал(а):Command line: "C:\Program Files\foobar2000\encoders\lame.exe" -V0 -q 0 -p "01 - The Ground Book (intro).mp3"
-V0 -q 0 -p - %d
G-Man писал(а):zotik писал(а):"C:\Program Files\foobar2000\Encoders\lame-3.98.3\lame.bat"
о_О
а может лучше exe-шник использовать?
http://audiophilesoft.ucoz.ua/publ/software/foobar2000_converter_setup/4-1-0-27
http://audiophilesoft.ucoz.ua/load/coders_utils/lame/7-1-0-30
Открываешь настройки, Converter -> MP3, перетаскиваешь ползунок на 320, конвертируешь. всё.но при конвертации выдаёт такую шляпу
плеер вообще отказывается конвертить, не только в мп3))meDveD писал(а):Открываешь настройки, Converter -> MP3 (LAME), перетаскиваешь ползунок на 320, конвертируешь. всё.но при конвертации выдаёт такую шляпу
Версия фубара должна быть 1.0.1 или выше.
Всё просто, выделяем весь треклист -> ПКМ -> Properties -> Utilities -> Edit CueSheet -> Внизу снимаем галочку -> "Enable embedded cue sheet on this file", заново открываем этот альбом и получаем image без вшитого cue.kombayn писал(а):здравствуйте, мучает такой вопрос:
есть альбомы образами *.wv, но в них прописаны куи (возможно еще обложки - при воспроизведении некоторые почему-то сильно подтормаживают). В итоге я хочу сжать сильнее, но вставляя образ в плейлист фубара показывается не 1 файл, а сразу весь альбом по песня и перекодировать не получается... как это сделать?!
