и как же решить эту проблему с сохранением не подскажете???Zin-Uru писал(а):2pieceofsummer
На следующем треке он обновляет обложку.acmodeu писал(а):хотя бы на каждой песне
значит только на x86 всё нормально.evil писал(а):Win 7 7600 64bit?
Подтверждаю! Новый 1.0 бета 1, Windows 7 7600 х64 - компонент работает как и раньше.SpirtRoyal писал(а):все путем у меня на 7 7600 64
foo_w7shell.dll : Windows 7 integration 0.2.8.1
Reason: Component problematic under foobar2000 versions older than 1.0 beta 1.
Common third party component problem with cross-thread SendMessage() inside a global callback has been worked-around on core side. While this in theory still is a component bug, the nature of the problem is too obscure for most component developers to know without studying MSDN in detail; additionally you have to be very careful regarding what third party code that you call does. Multiple components that were problematic in 0.9.x versions due to this problem are now entirely safe to use. This includes foo_w7shell and various instant messenger interaction components. The troubleshooter will be updated accordingly.
