Сообщение #1641 seriousstas » 30.01.2017, 23:44
kgena_ua
Пока не знаю.
тоже временно (может наведет на мысль ..)
тут, что добавил.
// ==PREPROCESSOR==
// @author "kgena_ua"
// @version "18012017"
// @feature "v1.4"
// @feature "watch-metadb"
// ==/PREPROCESSOR==
window.SetProperty(" - user:", "");
if (window.GetProperty(" - user:") != "" ) window.SetProperty(" - user:", "");
var font_name = window.GetProperty(" font name", "Arial");
var font_name2 = window.GetProperty(" font name2", "Arial");
var font_size = window.GetProperty(" font size", 12);
var font_size2 = window.GetProperty(" font size2", 22);
var font_style = window.GetProperty(" font style", 0);
var font_style2 = window.GetProperty(" font style2", 1);
var font = gdi.Font(font_name, font_size, font_style);
var font2 = gdi.Font(font_name2, font_size2, font_style2);
var ww = 600, wh = 600;
var pic_posx = 0;
var lbdn = 0;
DT_LEFT = 0x00000000;
DT_RIGHT = 0x00000002;
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_SINGLELINE = 0x00000020;
DT_NOPREFIX = 0x00000800;
MF_ENABLED = 0x00000000;
MF_GRAYED = 0x00000001;
MF_SEPARATOR = 0x00000800;
ColorTypeCUI = {
    text: 0,
    selection_text: 1,
    inactive_selection_text: 2,
    background: 3,
    selection_background: 4,
    active_item_frame: 6
ColorTypeDUI = {
   text: 0,
   background: 1,
   highlight: 2,
   selection: 3
function get_color(){
        a_color = window.GetColorDUI(ColorTypeDUI.text);
        b_color = window.GetColorDUI(ColorTypeDUI.highlight);
get_color();
function on_colors_changed(){
    get_color();
var transparent = window.GetProperty(" bg transparent (0-255)", 200);
var dir_name, album, artist;
var old_dir_name, old_album;
var g_img = null
var с_img = null
var cover_name;
var cover_size;
var cover_width;
var cover_height;
var cover_dim;
var nocover_path = window.GetProperty(" nocover path",".\\themes\\stub.png");
var nocover = window.GetProperty(" nocover image", true);
var nocover_transparent = window.GetProperty(" nocover transparent (0-255)", 100);
var covers_external = [];
var covers_dir = [];
var covers_root = [];
var covers_root_subs = [];
var covers_dir_subs = [];
var external = [];
var embedded = [];
var covers = [];
var images = [];
var covernumber = 0;
var attached_p_name = ["front cover", "back cover", "disc", "icon", "artist"];
var embedded_p_name = [];
var root_folders = new Array("cover", "covers", "scan", "scans", "art", "artwork", "artworks", "images", "pic");
var set_external = window.GetProperty("external", true);
var set_embedded = window.GetProperty("embedded", true);
var info = window.GetProperty("info", true);
var artist_txt = window.GetProperty("artist_txt", true);
var infoset = window.GetProperty("Infoset", 1);
var fader = 255;
var p_margin = window.GetProperty(" margin", 0);
var file_operation = false;
var delay = false;
var set_cycle = false;
var cycle_timer, step = 0;
var dis_timer, dis = 0;
var mode_1 = window.GetProperty("Mode 1", true);
var mode_2 = window.GetProperty("Mode 2", false);
var panel_on = true;
    draw_image(gr);
    draw_set(gr);
    draw_info(gr);
    gr.GdiDrawText( "", gdi.Font("Arial",12, 0), b_color, 10, 0, ww, wh, DT_LEFT | DT_WORD_ELLIPSIS );
    gr.GdiDrawText( "", gdi.Font("Arial",12, 0), b_color, 10, 30, ww, wh, DT_LEFT | DT_WORD_ELLIPSIS );
    gr.GdiDrawText( "", gdi.Font("Arial",12, 0), b_color, 10, 50, ww, wh, DT_LEFT | DT_WORD_ELLIPSIS );
var metadb;
on_item_focus_change();
function on_playback_stop() {
c_img = get_album_art(fb.GetNowPlaying());
    switch (selection_mode) {
    case 0:
    case 1:
       metadb = fb.GetFocusItem();
    if (metadb){
        t1 = fb.TitleFormat("$upper([%artist%])").Eval();
        artist = fb.Titleformat("%artist%").EvalWithMetadb(metadb);
            covernumber = 0;
            get_covers();
            old_dir_name = dir_name;
            old_album = album
function get_album_art(metadb) {
z = 0;
if (metadb)
return utils.GetAlbumArtV2(metadb, z);
function get_covers() {
    g_img = null;
    get_embedded_covers();
    external = set_external ? external : [];
    embedded = set_embedded ? embedded : [];
    covers = [];
    if (set_priority == 0) {
    if (set_priority == 1) {
    if (mode_2){
        images = []; // *************** v 2
            if (typeof covers[i] == 'object' ) {
                images.push(covers[i]);
                images.push(resize_image(gdi.Image(covers[i])));
    next_image(0);
function get_embedded_covers() {      //0 - front cover, 1 - back cover, 2 - disc, 3 - icon, 4 - artist
    embedded = [];
    if ( metadb ) {
        for (var i = 0; i < 5; i++) {
            var temp = utils.GetAlbumArtEmbedded(metadb.RawPath, i);
            if (temp) embedded_p_name.push(attached_p_name[i]);
    covers_dir = [];
    covers_root = [];
    external = [];
    try {
        dir = fso.GetFolder(path);
        root = dir.ParentFolder;
            var name = e.item().Path;
            for (i in root_folders) {
                if (sub_root_name.toLowerCase() == root_folders[i].toLowerCase()) {
    } catch(e) {};
    covers_external = covers_external.concat(covers_dir, covers_dir_subs, covers_root, covers_root_subs);
        if (external.length == 0){
            for (i in covers_external) {
                if ( get_fn(name).toLowerCase() == album.toLowerCase() )   {
                    external.push(name);
                    covers_external[i] = null;
                if ( get_fn(name).toLowerCase() == artist.toLowerCase() )   {
                if ( clear_n(get_fn(name)).toLowerCase() == clear_n(artist).toLowerCase() + clear_n(album).toLowerCase() )   {
                if (get_fnext(name).match(/.*(cover|front|folder|album).*\.(jpg|jpeg|gif|png)$/i )) {
    while (!e.atEnd()) {
        var name = e.item().Name;
            array.push( e.item().Path );
        e.moveNext();
function next_image(d){
    if (d < 0) {covernumber = covernumber <= 0 ? covers.length - 1 : covernumber = covernumber - 1};
    if (d > 0) {covernumber = covernumber >= covers.length - 1 ? 0 : covernumber = covernumber + 1};
    if (mode_1){
        if (typeof covers[covernumber] == 'object' ) {   // *************** v 1
            g_img = covers[covernumber];   // *************** v 1
        } else {   // *************** v 1
            g_img = resize_image(gdi.Image(covers[covernumber]));   // *************** v 1
        }   // *************** v 1
    if (mode_2) g_img = images[covernumber];  // *************** v 2
function resize_image(img){
    if (!img || !ww || !wh) return;
    var scale_w = ww / img.Width;
    var scale = Math.max(scale_w, scale_h);
    var nww = img.Width * scale;
    var nwh = img.Height * scale
    temp_gr.SetSmoothingMode(2);
    CollectGarbage();
    return temp_bmp;
    temp_bmp.Dispose();
    temp_gr = null;
    temp_bmp = null;
function draw_image(gr){
    if (g_img){
        gr.DrawRect(size.x, size.y, size.width, size.height, 1, RGBA(getRed(bgcolor),getGreen(bgcolor),getBlue(bgcolor),fader));
        gr.DrawImage(g_img, size.x, size.y, size.width, size.height, size.cx, size.cy, size.cwidth, size.cheight, 0, covers.length > 0 ? fader : nocover_transparent);
    if (!g_img){
      try {
    var size = calc_img_size(c_img);
    gr.DrawImage(c_img, size.x, size.y, size.width, size.height, size.cx, size.cy, size.cwidth, size.cheight, 0, covers.length > 0 ? fader : nocover_transparent);
      } catch (e) {};
 if (covers.length == 0 && nocover && fb.PlaybackLength > 0){
try {
      nc_img = gdi.Image(nocover_path);
   gr.DrawImage(nc_img, size.x, size.y, size.width, size.height, size.cx, size.cy, size.cwidth, size.cheight, 0, nocover_transparent);
    } catch(e) {};
    } else if (covers.length == 0 && nocover && fb.PlaybackLength <= 0 && typeof size != "object"){
   try {
      nc_img = gdi.Image(".\\themes\\radio_stub.png");
    } catch(e) {};
function draw_set(gr){
    if(set_cycle){
        gr.GdiDrawText("auto cycle:   " + txt_cycle, font, b_color, 0, 20, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
function draw_info(gr){
    var text_y = wh -  text_h * 3 - text_h / 3 - p_margin;
    if(info ){
        !set_cycle && gr.FillSolidRect(0, text_y - text_h / 3, ww, wh - text_y + text_h / 3, RGBA(getRed(bgcolor),getGreen(bgcolor),getBlue(bgcolor),transparent));
        if (covers[covernumber]) {
                if(fso.FileExists(covers[covernumber])){
                    cover_name = get_fnext(covers[covernumber]);
                    cover_width = gdi.Image(covers[covernumber]).width;
                    cover_height = gdi.Image(covers[covernumber]).Height;
                    cover_size = formatFileSize(fso.GetFile(covers[covernumber]).size);
                    cover_dim = cover_width + " x " + cover_height + "   " + cover_size;
                cover_name = get_embedded_p_name(covernumber);
                cover_dim = "embedded";
            !artist_txt && cover_name && gr.GdiDrawText( cover_name, font, b_color, 0, text_y-2, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS | DT_NOPREFIX );
            !artist_txt && gr.GdiDrawText( cover_dim, font, a_color, 0, text_y + text_h, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
            info_text = covernumber + 1 + " (" + covers.length + ")   " + external.length + " external   " + embedded.length + " embedded";
            !artist_txt && gr.GdiDrawText( info_text, font, a_color, 0, text_y + text_h * 2, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
   // if (!g_img) {
     // gr.GdiDrawText("no image", font, a_color, 0, 0, ww, wh, DT_SINGLELINE | DT_CENTER | DT_VCENTER | DT_WORD_ELLIPSIS );
    artist_txt && gr.GdiDrawText(t1, font2, b_color, 0, text_y-5 + text_h, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
pic_posx = x;
lbdn = 1
    //infoset = window.GetProperty("Infoset");
  infoset++;
if (infoset > 3)
infoset = 1;
window.SetProperty("Infoset",infoset);
if (pic_posx == x) {
if (infoset == 1){
        artist_txt = true;
        window.SetProperty("artist_txt", artist_txt)
    info = true;
        window.SetProperty("info", info); }
if (infoset == 2){
         info = true;
                artist_txt = false;
        window.SetProperty("artist_txt", artist_txt)}
if (infoset == 3){
        artist_txt = false;
        info = false;
        window.SetProperty("info", info)}
      lbdn = 0;
    /*if (typeof covers[covernumber] != 'object' ) {
        if(!fso.FileExists(covers[covernumber]))return;
    if (!delay && !set_cycle && covers.length > 1){
        delay = true;
        fdelay();
        next_image(delta);
    if (ShiftDown) {
                if (cycle > 0)
         step = 0;
    if (lbdn) {
          if (x > pic_posx+30) {
         next_image(1);
            lbdn = 0;
      if (x < pic_posx-30 ) {
         next_image(-1);
         lbdn = 0;
    window.SetCursor(32649);
function on_mouse_leave() {
    window.SetCursor(32512);
function fdelay(){
        delay = false;
    }, 200);
function on_key_down(vkey) {
    if (vkey == 16){
        set_cycle = true;
        dis_set();
function set_cycle_timer(){
        step =  set_cycle || file_operation ? 0 : step + 1;
            if ( covers.length > 1) next_image(1);
            step = 0;
    }, 1000 );
function dis_set(){
    dis = 0;
        if (set_cycle) {
            dis++;
            if(dis == 1) {
                set_cycle = false;
    }, 1000 );
var ftimer;
function fader_timer(){
    fader = fader + fade_step;
        if (fader >= 255) {
            fader= 255;
            window.ClearInterval(ftimer);
    }, 50 );
function change_filename(){
    var c_file_name = get_fn(covers[covernumber]);
    var nl = "\" + chr(10) + \"";
    var input_box_text = nl + "Enter new file name";
    var n_file_name = input_box(input_box_text, c_file_name, "Foobar 2000");
    if (n_file_name) {
        var dir = get_dp(covers[covernumber]);
        var ext = get_fext(covers[covernumber]);
        try {
            get_covers();
                if (get_fn(covers[i]) == n_file_name) {
                    covernumber = i;
        } catch(e) {}
function delete_file(){
    var button_type = is_read_write(source) ? 0x3 : 0x5;
    var icon_type = is_read_write(source) ? 0x20 : 0x10;
    var second_button_is_default = 0x100;
    var btn = WshShell.Popup("Delete file:\n\n" + source, 0, "Foobar 2000", button_type + icon_type + second_button_is_default);
    switch (btn) {
    case 6:
        try{
            fso.DeleteFile(source);
            get_covers();
        } catch(e) {}
    case 2:
    case 7:
    case 4:
        delete_file();
function change_file_attributes(){
    var txt = is_read_write(source) ? "file is \nREAD-WRITE" : "file is \nREAD-ONLY";
    var button_type = 0x3;
    var icon_type = 0x40;
    var btn = WshShell.Popup(source + "\n\n" + txt + "\nchange file attributes ?", 0, "Foobar 2000", button_type + icon_type);
    switch (btn) {
    case 6:
        try{
            file.Attributes = is_read_write(source) ? 33 : 32;
        } catch(e) {}
    case 2:
    case 7:
    vbe.Language = 'VBScript';
function is_read_write(f){
    if(fso.FileExists(f)) {
        var file = fso.GetFile(f);
        return file.Attributes == 32 ? true : false;
function on_size(){
function calc_img_size(img){
    switch(align_mode) {
   case 0: // adjust
        var sw = ww / img.Width;
        var sh = wh / img.Height;
        var s = Math.min(sw, sh);
        var x = 0;
        var y = 0;
        var width = img.Width * s;
        var height = img.Height * s;
        var cx = 0;
        var cy = 0;
        var cwidth = img.Width;
        var cheight = img.Height;
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
    case 2: // adjust top - left
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
   case 3: // centre
      var dr = ww / wh;
      if (sr < dr) {
         var r = img.Width / ww;
         var cheight = wh * r;
         var cx = 0;
         var r = img.Height / wh;
         var cwidth = ww * r;
         var cy = 0;
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
   case 4: // centre - top
      var dr = ww / wh;
      if (sr < dr) {
         var cy = 0;
         var cx = 0;
         var cy = 0;
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
   case 5: // stretch
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
        var cx = 0;
        var cy = 0;
    size.x = x + p_margin;
    size.y = y + p_margin;
    size.cx = cx;
    size.cy = cy;
    size.cwidth = cwidth;
    size.cheight = cheight;
    return size;
function get_embedded_p_name(n){
        idx = n - external.length;
         idx = n ;
    return embedded_p_name[idx];
    _menu.AppendMenuItem(MF_ENABLED, 10, "External covers");
    _menu.CheckMenuItem(10, set_external);
    _menu.AppendMenuItem(MF_ENABLED, 11, "Embedded covers");
    _menu.CheckMenuItem(11, set_embedded);
    _menu.AppendMenuItem(MF_ENABLED, 20, "Priority external");
    _menu.AppendMenuItem(MF_ENABLED, 21, "Priority embedded");
    _menu.CheckMenuRadioItem(20, 21 , set_priority + 20);
   _menu.EnableMenuItem(set_priority + 20, 1);
    _menu.AppendMenuItem(MF_ENABLED, 30, "Prefer now playing");
    _menu.AppendMenuItem(MF_ENABLED, 31, "Follow selected track");
    _menu.CheckMenuRadioItem(30, 31 , selection_mode + 30);
   _menu.EnableMenuItem(selection_mode + 30, 1);
    _menu.AppendMenuItem(MF_ENABLED, 40, "Info");
    _menu.CheckMenuItem(40, info);
    _menu.AppendMenuItem(MF_ENABLED, 41, "Artist txt");
    _menu.CheckMenuItem(41, artist_txt);
    _firstgroup.AppendTo(_menu, MF_ENABLED, "Align : " + align_mode_a[align_mode]);
    _firstgroup.AppendMenuItem(MF_ENABLED, 60, align_mode_a[0]);
    _firstgroup.AppendMenuItem(MF_ENABLED, 61, align_mode_a[1]);
    _firstgroup.AppendMenuItem(MF_ENABLED, 62, align_mode_a[2]);
    _firstgroup.AppendMenuItem(MF_ENABLED, 63, align_mode_a[3]);
    _firstgroup.AppendMenuItem(MF_ENABLED, 64, align_mode_a[4]);
    _firstgroup.AppendMenuItem(MF_ENABLED, 65, align_mode_a[5]);
    _firstgroup.CheckMenuRadioItem(60, 65, align_mode + 60);
    _firstgroup.EnableMenuItem(align_mode + 60, 1);
    MF_STRING = covers[covernumber] && typeof covers[covernumber] != 'object' ? MF_ENABLED : MF_GRAYED;
    _menu.AppendMenuItem(MF_STRING, 70, "Open folder");
    _menu.AppendMenuItem(MF_STRING, 71, "Rename file");
    _menu.AppendMenuItem(MF_STRING, 72, "Delete file");
    _menu.AppendMenuItem(MF_STRING, 73, "Change file attributes");
    MF_STRING = mode_2 ? MF_ENABLED : MF_GRAYED;
    _menu.AppendMenuItem(MF_STRING, 80, "Mode 1");
    _menu.CheckMenuItem(80, mode_1);
    MF_STRING = mode_1 ? MF_ENABLED : MF_GRAYED;
    _menu.AppendMenuItem(MF_STRING, 81, "Mode 2");
    _menu.CheckMenuItem(81, mode_2);
    switch (ret) {
    case 10:
        set_external = set_external == false ? true : set_embedded == false ? true : false;
        covernumber = 0;
        get_covers();
    case 11:
        set_embedded = set_embedded == false ? true : set_external == false ? true : false;
        window.SetProperty("embedded", set_embedded);
        covernumber = 0;
        get_covers();
    case 20:
    case 21:
        set_priority = ret - 20;
        covernumber = 0;
        get_covers();
    case 30:
    case 31:
        selection_mode = ret - 30;
    case 40:
         info = !info
       if (info == false){
        artist_txt = false;
    case 41:
        artist_txt = !artist_txt
        window.SetProperty("artist_txt", artist_txt);
       if (artist_txt == true){
        info = true;
    case 50:
    case 60:
    case 61:
    case 62:
    case 63:
    case 64:
    case 65:
        align_mode = ret - 60;
    case 70:
    case 71:
        file_operation = true;
        change_filename();
    case 72:
        delete_file();
    case 73:
        change_file_attributes();
    case 80:
    case 81:
        window.SetProperty("Mode 1", !mode_1);
        mode_1 = window.GetProperty("Mode 1");
        window.SetProperty("Mode 2", !mode_1);
        mode_2 = window.GetProperty("Mode 2");
        covernumber = 0;
        get_covers();
    case 100:
        try {
            window.Reload();
        } catch(e) {};
    case 110:
        window.ShowProperties();
    case 120:
        window.ShowConfigure();
    _menu.Dispose();
    return true;
function get_fnext(p) {
    if (!p) return;
    return p.replace(/.*\\/g,'');
function get_fn(p) {
    if (!p) return;
    return p.replace(/.*\\|\.[^.]+$/g,'')
function get_fext(p) {
    if (!p) return;
    return p.replace(/.*\./g,'');
function get_dp(p) {
    if (!p) return;
    return p.replace(/(.*)\\.*/g,'$1');
function clear_n(p) {
    if (!p) return;
    return p.replace(/[^a-zA-Zа-яА-ЯёЁ0-9]/g,'');
function formatFileSize(b){
    if (b > 1024 * 1024){
        b = Math.round(b / 1024 / 1024 * 100) / 100 + " MB"
    } else if (b > 1024){
        b = Math.round(b / 1024 * 100 ) / 100 + " KB"
        b = b + " Bytes";
    return b;
Сообщение #1642 Aliado_71 » 31.01.2017, 00:26
seriousstas, спасибо, скрипт работает, ждем финал :smile:
С нами: 10 лет 2 месяца
Сообщение #1643 seriousstas » 31.01.2017, 00:43
Не за что, я особо там ничего не трогал, но есть вопросы к
kgena_ua
из того что успел затестить в авто ..
Там это всегда стресс тест , тк процессор и начинка ноутбучная.
что получилось (по памяти ). Тест на 6-ти канальныйх SACD.iso , когда процессор на 40-60% работает .
Mode 1 :
Фубар стартует быстро , но переключение "толстых" картинок вешает плеер на 1-2 секунды.
Mode 2 :
Фубар запускается от 2-х до 5-ти секунд (автоплей включен) :eh: ,
но картинки листаются довольно быстренько .
Вот надеюсь , появится какойнибудь Mode 3 (возможно нужно просто таймаут добавить ..) , где будет золотая середина .
Конечно на шустрых домашних ПК переключение будет не столь заметно , но если нагрузить немного библиотеку ,
то Mode 2 даже на домашнем задерживал запуск на 1-3 секунды
В авто это критично , тк там фтонтенд перехватывает окно Фубара .
Сообщение #1644 kgena_ua » 02.02.2017, 18:46
seriousstas, по режимам. Задержка связана с размером картинок. Но в любом случае я не наблюдал 1-2 секунды, доли секунды, даже на слабом компе, на работе, например.
Тестирование
Get Covers (Artwork) и Radio Logo. Два скрипта в одном.
В Properties добавлен пункт radio logo dir name
Get Covers (Artwork) && radio logos
version 02022017
// ==PREPROCESSOR==
// @name "Get Covers (Artwork) && radio logos"
// @version "02022017"
// @feature "v1.4"
ColorTypeCUI = {
    text: 0,
    selection_text: 1,
    background: 3,
ColorTypeDUI = {
   text: 0,
   background: 1,
   highlight: 2,
   selection: 3
get_color();
    get_color();
htmlfile = new ActiveXObject('htmlfile');
var clipboardData = "";
var logo_file_name, old_logo_file_name, logo_files = [];
var path, title, itle_stream, artist_stream, genre;
var t_type, old_t_type;
var g_img = null
var cover_name;
var cover_size;
var cover_width;
var cover_height;
var cover_dim;
var nocover_path = window.GetProperty(" nocover path",".\\maybe\\textures\\nocover\\nocover.png");
var nocover = window.GetProperty(" nocover image", false);
var external = [];
var embedded = [];
var covers = [];
var images = [];
var fader = 255;
var delay = false;
var logo_dir_name = window.GetProperty(" radio logo dir name",".\\radio Logos\\");
//var panel_on = true;
get_logo_files_from_dir();
    draw_image(gr);
    switch (t_type) {
    case "file":
        draw_set(gr);
        draw_info(gr);
    case "stream":
        draw_info_stream(gr);
    gr.GdiDrawText( "", gdi.Font("Arial",12, 0), b_color, 10, 70, ww, wh, DT_LEFT | DT_WORD_ELLIPSIS );
var metadb;
    case 0:
    case 1:
    if (metadb){
        title = fb.Titleformat("[%title%]").EvalWithMetadb(metadb);
        title_stream = fb.Titleformat("[%title%]").Eval();
        artist_stream = fb.Titleformat("[%artist%]").Eval();
        genre = fb.Titleformat("[%genre%]").EvalWithMetadb(metadb);
        t_type = track_type(metadb.RawPath);
        if (old_t_type != t_type){
            g_img = null;
            old_t_type = t_type;
        switch (t_type) {
        case "file":
                covernumber = 0;
                get_covers();
                old_album = album;
                old_logo_file_name = "";
        case "stream":
            covernumber = 0;
            get_logo_image();
            old_dir_name = "";
            old_album  = "";
    covers = [];
    if (mode_2){
    next_image(0);
    embedded = [];
    if ( metadb ) {
    covers_dir = [];
    covers_root = [];
    external = [];
    try {
    } catch(e) {};
    //covers_external = covers_external.concat(covers_dir, covers_root, covers_dir_subs, covers_root_subs);
    //covers_external = covers_external.concat(covers_root, covers_root_subs, covers_dir, covers_dir_subs);
        e.moveNext();
    if (mode_1){
    CollectGarbage();
    return temp_bmp;
    temp_bmp.Dispose();
    temp_gr = null;
    temp_bmp = null;
    if (g_img){
    if (images.length == 0 && nocover){
        try {
        } catch(e) {};
    if (!g_img) {
    if(set_cycle){
    if(info && g_img){
            cover_name && gr.GdiDrawText( cover_name, font, b_color, 0, text_y, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS | DT_NOPREFIX );
function draw_info_stream(gr){
    var text_y = wh -  text_h * 4 - text_h / 4 - p_margin;
    if (info){
        gr.FillSolidRect(0, text_y - text_h / 4, ww, wh - text_y + text_h / 4, RGBA(getRed(bgcolor),getGreen(bgcolor),getBlue(bgcolor),transparent));
        gr.GdiDrawText( title_stream, font, b_color, 0, text_y, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS | DT_NOPREFIX );
        gr.GdiDrawText( artist_stream, font, b_color, 0, text_y + text_h, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
        gr.GdiDrawText( title, font, a_color, 0, text_y + text_h * 2, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
        gr.GdiDrawText( genre, font, a_color, 0, text_y + text_h * 3, ww, wh, DT_CENTER | DT_WORD_ELLIPSIS );
    if (!delay && !set_cycle && covers.length > 1 && t_type == "file"){
        delay = true;
        fdelay();
        next_image(delta);
    if (ShiftDown) {
function fdelay(){
        delay = false;
    }, 200);
    if (vkey == 16){
        set_cycle = true;
        dis_set();
        if (cycle > 0 && step >= cycle && t_type == "file"){
            step = 0;
    }, 1000 );
function dis_set(){
    dis = 0;
        if (set_cycle) {
            dis++;
            if(dis == 1) {
                set_cycle = false;
    }, 1000 );
var ftimer;
        if (fader >= 255) {
            fader= 255;
    }, 50 );
    if (n_file_name) {
        try {
            get_covers();
                    covernumber = i;
        } catch(e) {}
    switch (btn) {
    case 6:
        try{
            get_covers();
        } catch(e) {}
    case 2:
    case 7:
    case 4:
        delete_file();
    switch (btn) {
    case 6:
        try{
        } catch(e) {}
    case 2:
    case 7:
function on_size(){
   case 0: // adjust
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
   case 3: // centre
      var dr = ww / wh;
      if (sr < dr) {
         var cx = 0;
         var cy = 0;
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
      var dr = ww / wh;
      if (sr < dr) {
         var cy = 0;
         var cx = 0;
         var cy = 0;
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
   case 5: // stretch
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
        var cx = 0;
        var cy = 0;
    size.cx = cx;
    size.cy = cy;
    return size;
         idx = n ;
    MF_STRING = t_type ==  "file" ? MF_ENABLED : MF_GRAYED;
    _menu.AppendMenuItem(MF_STRING, 10, "External covers");
    _menu.AppendMenuItem(MF_STRING, 11, "Embedded covers");
    _menu.AppendMenuItem(MF_STRING, 20, "Priority external");
    _menu.AppendMenuItem(MF_STRING, 21, "Priority embedded");
    MF_STRING = covers[covernumber] && typeof covers[covernumber] != 'object' && t_type ==  "file" ? MF_ENABLED : MF_GRAYED;
    if (t_type ==  "stream"){
        _menu.AppendMenuItem(MF_ENABLED, 80, "Copy filename to clipboard");
    _menu.AppendMenuItem(MF_STRING, 90, "Mode 1");
    _menu.CheckMenuItem(90, mode_1);
    _menu.AppendMenuItem(MF_STRING, 91, "Mode 2");
    _menu.CheckMenuItem(91, mode_2);
    switch (ret) {
    case 10:
        covernumber = 0;
        get_covers();
    case 11:
        covernumber = 0;
        get_covers();
    case 20:
    case 21:
        covernumber = 0;
        get_covers();
    case 30:
    case 31:
    case 40:
    case 50:
    case 60:
    case 61:
    case 62:
    case 63:
    case 64:
    case 65:
    case 70:
    case 71:
        change_filename();
    case 72:
        delete_file();
    case 73:
    case 80:
        htmlfile.parentWindow.clipboardData.setData("text", title.replace(/[^a-zA-Z0-9а-яА-Я\s-]/g,'').replace(/\s+/g,' ').replace(/^\s+|\s+$/g,""));
    case 90:
    case 91:
        covernumber = 0;
        switch (t_type) {
        case "file":
            get_covers();
        case "stream":
            get_logo_image();
    case 100:
        try {
            window.Reload();
        } catch(e) {};
    case 110:
    case 120:
    _menu.Dispose();
    return true;
    if (!p) return;
    if (!p) return;
    if (!p) return;
    if (!p) return;
    if (!p) return;
        b = b + " Bytes";
    return b;
function get_logo_image() {
    for (var i = 0; i < logo_files.length; i++){
        var file = logo_files[i].replace(/.jpg|.jpeg|.png|.gif|.bmp|.tiff/g,'').replace(/[^a-zA-Z0-9а-яА-я]/g,'');
        var tfname = title.replace(/[^a-zA-Z0-9а-яА-я]/g,'');
        if (tfname.toLowerCase() == file) logo_file_name = logo_files[i];
    if (logo_file_name != old_logo_file_name){
        covers = [];
        covers.push(logo_dir_name + logo_file_name);
        if (mode_2){
            images.push(resize_image(gdi.Image(covers[0])));
        next_image(0);
        old_logo_file_name = logo_file_name;
function get_logo_files_from_dir() {
    if(!fso.FolderExists(logo_dir_name)) return;
    logo_files = [];
    var e = new Enumerator( fso.GetFolder(logo_dir_name).files );
    while ( !e.atEnd() ) {
        name = name.toLowerCase();
        logo_files.push(name);
        e.moveNext();
function track_type(p) {
    var type;
    if (p.indexOf("file") >= 0){
        type = "file";
    } else if (p.indexOf("cdda") >= 0){
        type = "cdda";
    } else if (p.indexOf('://') >= 0 || p.indexOf('www') >= 0 || p.indexOf("youtube") >= 0 || p.indexOf("video") >= 0 || p.indexOf("vimeo") >= 0){
        type = "stream";
        type = "";
    return type;
Сообщение #1645 kutuzof » 02.02.2017, 19:18
kgena_ua, супер. Вроде работает. Спасибо большое.
Сообщение #1646 seriousstas » 02.02.2017, 20:18
kgena_ua
По картинкам понятно .
На флаках так и есть - малозаметно .
Повторюсь :
сравниваю с Maxim Terpilovsky's script ...
Сообщение #1647 kgena_ua » 02.02.2017, 21:31
seriousstas, приветствую
seriousstas:Тест на 6-ти канальныйх
да, не пробовал, согласен, вполне возможно.
У Максима рисует через gr.GdiDrawBitmap, а все остальное почти одинаково, и различия не влияют никак на скорость.
И я наверное сделаю через gr.GdiDrawBitmap при отключенном фейдер - эффекте.
Сообщение #1648 seriousstas » 02.02.2017, 21:53
kgena_ua Доброго вечера! :hi:
по Mode1 ..
по Mode2 есть явные преимущества, но что-то происходит на старте ..
Сообщение #1649 MC Web » 02.02.2017, 23:48
kgena_ua, привет.
Закинул Get Covers (Artwork) & Radio Logos себе в копилку, спасибо.
Скрипт Biography Text & Picture last.fm потихоньку набирает популярность не только в Китае, наткнулся тут.
Сообщение #1650 Aliado_71 » 03.02.2017, 00:24
kgena_ua, :hi: Спасибо! Сейчас отлично! :beer:
Сообщение #1651 kutuzof » 03.02.2017, 09:59
kgena_ua здравствуйте, при включенном режиме отображения картинки, картинка перекрывает обложку. или так задумано?
Сообщение #1652 kgena_ua » 03.02.2017, 16:22
kutuzof, да нет, это не нормально. У меня nocover всегда выключен, вот и не обращал внимание. Это не проблема....
стр. 236
заменить на
    if (!g_img && nocover){
Сообщение #1653 kgena_ua » 08.02.2017, 20:18
version "08022017"
Изменения касаются режима 1 и режима 2 - для картинок с большим разрешением.
изменения в :
seriousstas, обратите внимание.
// ==PREPROCESSOR==
// @version "08022017"
// @feature "v1.4"
ColorTypeCUI = {
    text: 0,
    selection_text: 1,
    background: 3,
ColorTypeDUI = {
   text: 0,
   background: 1,
   highlight: 2,
   selection: 3
get_color();
    get_color();
var g_img = null
var cover_name;
var cover_size;
var cover_width;
var cover_height;
var cover_dim;
var external = [];
var embedded = [];
var covers = [];
var images = [];
var fader = 255;
var delay = false;
    draw_image(gr);
    switch (t_type) {
    case "file":
        draw_set(gr);
        draw_info(gr);
    case "stream":
var metadb;
    case 0:
    case 1:
    if (metadb){
            g_img = null;
        switch (t_type) {
        case "file":
                covernumber = 0;
                get_covers();
                old_album = album;
        case "stream":
            covernumber = 0;
            get_logo_image();
            old_dir_name = "";
            old_album  = "";
    covers = [];
    images = [];
    if (mode_2){
                images.push(resize_image(covers[i]));
    next_image(0);
    embedded = [];
    if ( metadb ) {
    covers_dir = [];
    covers_root = [];
    external = [];
    try {
    } catch(e) {};
                if (artist && album){
        e.moveNext();
    if (mode_1){
            g_img = resize_image(covers[covernumber]);
    if (mode_2){
    var size = calc_img_size(img);
    return img.Resize(size.width, size.height, 2);
    if (g_img){
        try {
        } catch(e) {};
    if (!g_img) {
    if(set_cycle){
    if(info && g_img){
    if (info){
        delay = true;
        fdelay();
        next_image(delta);
    if (ShiftDown) {
function fdelay(){
        delay = false;
    }, 200);
    if (vkey == 16){
        set_cycle = true;
        dis_set();
            step = 0;
    }, 1000 );
function dis_set(){
    dis = 0;
        if (set_cycle) {
            dis++;
            if(dis == 1) {
                set_cycle = false;
    }, 1000 );
var ftimer;
        if (fader >= 255) {
            fader= 255;
    }, 50 );
    if (n_file_name) {
        try {
            get_covers();
                    covernumber = i;
        } catch(e) {}
    switch (btn) {
    case 6:
        try{
            get_covers();
        } catch(e) {}
    case 2:
    case 7:
    case 4:
        delete_file();
    switch (btn) {
    case 6:
        try{
        } catch(e) {}
    case 2:
    case 7:
function on_size(){
   case 0: // adjust
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
        var x = 0;
        var y = 0;
        var cx = 0;
        var cy = 0;
   case 3: // centre
      var dr = ww / wh;
      if (sr < dr) {
         var cx = 0;
         var cy = 0;
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
      var dr = ww / wh;
      if (sr < dr) {
         var cy = 0;
         var cx = 0;
         var cy = 0;
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
   case 5: // stretch
        var x = 0;
        var y = 0;
        var width = ww;
        var height = wh;
        var cx = 0;
        var cy = 0;
    size.cx = cx;
    size.cy = cy;
    return size;
         idx = n ;
    switch (ret) {
    case 10:
        covernumber = 0;
        get_covers();
    case 11:
        covernumber = 0;
        get_covers();
    case 20:
    case 21:
        covernumber = 0;
        get_covers();
    case 30:
    case 31:
    case 40:
    case 50:
    case 60:
    case 61:
    case 62:
    case 63:
    case 64:
    case 65:
    case 70:
    case 71:
        change_filename();
    case 72:
        delete_file();
    case 73:
    case 80:
    case 90:
    case 91:
        covernumber = 0;
        switch (t_type) {
        case "file":
            get_covers();
        case "stream":
            get_logo_image();
    case 100:
        try {
            window.Reload();
        } catch(e) {};
    case 110:
    case 120:
    _menu.Dispose();
    return true;
    if (!p) return;
    if (!p) return;
    if (!p) return;
    if (!p) return;
    if (!p) return;
        b = b + " Bytes";
    return b;
        covers = [];
        if (mode_2){
        next_image(0);
    logo_files = [];
        e.moveNext();
    var type;
        type = "file";
        type = "cdda";
        type = "stream";
        type = "";
    return type;
Сообщение #1654 seriousstas » 09.02.2017, 03:36
kgena_ua
Спасибо , первые тесты - все отлично!
Сообщение #1655 duzzy » 09.02.2017, 17:08
kgena_ua, привет !
В скрипте Get Covers (Artwork) && radio logos version "08022017" ошибка.
Аспект не верный, картинки тянет на всю панель в режимах которые не "adjust".
Подозреваю что дело в function resize_image(img) ---> return img.Resize(size.width, size.height, 2);
duzzy
С нами: 9 лет 10 месяцев
Сообщение #1656 AHAPXICT » 09.02.2017, 23:43
duzzy, приветствую. Причём если поставить строки с предыдущей версии то всё работает, но как я понимаю это не выход.
kgena_ua, у меня к вам вопрос или это больше мысль. За несколько лет так привык переключать обложки по ЛКМ, что теперь просто по другому не могу. Вот и добавил себе такое переключение для Get Covers (Artwork) для левой кнопки по одному клику, а открытие программы просмотра на среднюю кнопку мыши чтобы если быстро клацаешь не активировалась программа по двойному клику. Вот собственно и всё что хотел сказать. Как вы на это смотрите?
function on_mouse_lbtn_down (x, y) {
    if (!delay && step >= cycle){
        if (covers.length > 1) next_image(1);
        step = 0;
function on_mouse_mbtn_down (x,y){
P.S. Уже вышел с форума и тут ещё одна мысль в голову пришла. Перематывая буклет альбома в разных режимах понял одну вещь, аналогов такого не встречал. Раз уж сейчас коснулись режимов масштабирования картинки это касается развёрнутого буклета CD. На сколько я понимаю окно для просмотра обложек у всех как правило квадратное, то если придумать ещё один режим с анализом картинки по сторонам с условием если ширина равна примерно высоте умноженной на 2, то показывать сначала левую половину картинки, а потом правую. В идеале получается идеально разрезанный буклет пополам. Но это так мысль в слух. На сколько себе могу представить условий получится до хрена и больше.
Сообщение #1657 kgena_ua » 10.02.2017, 19:04
duzzy, да, resize_image().
В общем так:
в.02022017 работоспособная, можно пользоваться.
в.08022017 немного отличается, мелкие исправления, например тестировал какой-то скрипт, и он (скрипт) создал автоплейлист без значений тегов артист и альбом, как результат вылет - исправил в в.08022017. Добавил отображение размеров для вшитых обложек, и т.д.
по resize_image() остановился на такой версии:
    var nww = Math.round(img.Width * scale);
    var nwh = Math.round(img.Height * scale)
    return img.Resize(nww, nwh, 2);
    img && img.Dispose();
для любой версии, и для биографии.
AHAPXICT:и тут ещё одна мысль в голову пришла
Лучшим способом реализации вижу:
- режим выравнивания - "по центру";
- мышкой двигаем изображение влево, вправо, вверх и вниз.
Сообщение #1658 kgena_ua » 11.02.2017, 13:57
Давно бьюсь с проблемой:
почему при старте скрипта не отрабатывают функции
window.Width;
и
window.Height;
Сообщение #1659 duzzy » 11.02.2017, 14:03
AHAPXICT
Привет !
Да если использовать строки из прошлой версии все гуд.
Все работает прекрасно тут только одна сложность, это большие обложки, т.е. обложки с большим разрешением.
И на сколько я понимаю тут особо ничего не сделать...
Скрипт kgena_ua работает намного быстрее аналогов, проверено на разных устройствах.
kgena_ua
Попробовал и мне кажется это не лучший вариант, потому как на порядок возрастает жор памяти на жирных обложках.
У меня иногда было больше 1 гб. при загрузке новых обложек на новом треке.
Прошлый вариант из "Get Covers (Artwork)" version "18012017" лучше отрабатывает...
function resize_image(img) {
      return;
   CollectGarbage();
   return temp_bmp;
   temp_bmp.Dispose();
   temp_gr = null;
   temp_bmp = null;
Возможно я конечно не прав но может быть установить небольшую задержку при переходе на следующий трек, для того что бы метод ресайза отрабатывал чуть позже начала проигрывания трека.
Это будет что то вроде отложенной загрузки как например при автозагрузке в винде, когда в автозагрузке все грузится до кучи в один момент возникает излишняя нагрузка и загрузка увеличивается.
Для ускорения можно использовать механизм отложенной загрузки...
Т.е. установить задержки при загрузке программ...
Грубый пример:
задержка-1 --- 1 сек.
грузим программу №1
задержка-2 --- 1 сек.
грузим программу №2
задержка-3 --- 1 сек.
грузим программу №3
Т.е. по сути мы даем возможность программе нормально загрузится и продолжаем загрузку программ дальше.
Можно поинтересоваться почему ты не хочешь использовать gr.GdiDrawBitmap(...)(он работает быстрее чем gr.DrawImage(...)) ?
Из за эффекта фэйда да ?
duzzy
Сообщение #1660 AHAPXICT » 11.02.2017, 15:37
duzzy, kgena_ua, Приветствую!
kgena_ua:Лучшим способом реализации вижу:
Это не "хотелка" была, а просто мысль такая стрельнула, вот и написал. По большому счёту скрипт самодостаточный и всё в нём есть, а у меня в голове рождаются всякие идеи которые по истечению времени идут в топку :smile:
