Обсуждение пользовательских индикаторов для foo_vis_vumeter
Сообщение #101 onv » 19.03.2013, 03:45
Cov:Then again, looking at the spinning tapes might well get boring soon.
absolutely true
Cov:Seems like everything interesting has already been done, right?
no, creative ideas are endless, just need to carefully consider what has already been done by other people.
onv M
Сообщение #102 Cov » 19.03.2013, 07:41
Hi, I have a different question please. This is not really related to Foobar.
I like system monitoring tools for Windows 7, but I have not found the right design yet.
For example I use Chameleon Glass gadgets by gersma. They have a clean and neat look.
Because I love the VU Meters with needles (of Foobar) very much, I was thinking of something similar for System Monitoring:
• download speed
• upload speed
• CPU usage
• CPU frequency
• CPU temperature
• RAM usage
• usage of each hard drive
• RPM of CPU and AUX fan, etc
This dial is just an example:
I'm afraid this is too off topic for my kind of problem, right?
Cov
С нами: 10 лет 6 месяцев
Сообщение #103 macarych » 19.03.2013, 12:48
Cov, you want VU meter with round scale?
С нами: 14 лет 8 месяцев
Сообщение #104 onv » 19.03.2013, 15:21
Cov:I'm afraid this is too off topic for my kind of problem, right?
Yep, it's offtopic in this thread.
Cov:Because I love the VU Meters with needles (of Foobar) very much, I was thinking of something similar for System Monitoring:
This can be done with WSH code, not with foo_vis_vumeter. In WSH you can create a scale and arrow, what you need, and use instead the signal level CPU temperature, memory usage etc.
For example :
http://foobar2000.0pk.ru/viewtopic.php?id=410
onv M
Сообщение #105 Cov » 19.03.2013, 18:45
Hello macarych,
that is an interesting idea.
The only (semi) round scales I have found are these two:
The top one is beautiful (!) but the bottom scale has the wrong units.
Maybe something similar to this ...
... or this ...
... or this ...
... or this ...
Добавлено спустя 5 минут 58 секунд:
This can be done with WSH code, ...
Hi onv,
thank you for the info!
I really want to make this work one day.
:smile:
Cov
Сообщение #106 macarych » 19.03.2013, 19:50
Cov:Maybe something similar to this ...
It is not difficult to make, try it yourself.
Сообщение #107 Cov » 20.03.2013, 02:42
Oh macarych, I have no knowledge of how to do this. I have never done this before.
I was happy to find out how to install new VU Meters for the Foobar skin NEUTRON with your help.
Is there a easy to understand guide existing of how to do this?
Cov
Сообщение #108 macarych » 20.03.2013, 06:18
Cov:Is there a easy to understand guide existing of how to do this?
http://youtu.be/jhqqqkdvABw
http://youtu.be/71RQyWC7Id4
Сообщение #109 Cov » 20.03.2013, 06:27
Thank you!
Cov
Сообщение #110 biko » 22.03.2013, 13:51
Cov, а можно такой skin foobar скинуть ?
biko
Сообщение #111 Cov » 22.03.2013, 13:58
привет biko
Я думаю, что это сложно
Я сожалею
Cov
Сообщение #112 vladj » 22.03.2013, 16:08
biko, если это не монтаж, а истинный скрин, то скорей всего сборка в автомобильном компе, стрелочники
выведены на полный размер окна фубара, а ниже панель очень похожая на ту, что можно сделать в программе
компас, т.е. электронный аналог приборной панели автомобиля. ИМХО.
С нами: 13 лет 8 месяцев
Сообщение #113 macarych » 22.03.2013, 16:36
vladj:biko, если это не монтаж, а истинный скрин, то скорей всего сборка в автомобильном компе, стрелочники
Я извиняюсь, про какую это, вы тут, сборку рассуждаете? На первом скрине cov'a два куска, еще раз извиняюсь, из моих сборок :oops:
Сообщение #114 macarych » 26.03.2013, 16:49
foo_vis_vumeter revue 2
Сообщение #115 vladj » 26.03.2013, 20:38
То, что сверху твоё, это я-ж сразу понял, то, что внизу скрина, просто не ожидал, что кто-либо будет пользоватся таким суррогатом
тахометра и спидометра в сборке, ну если только ради прикола поставить, да и то, как-то не катит, я думаю.
Просто пользователи ставят мониторы в авто и вертикально, выводя в верхней половине мультимедиа, а ниже истинную электронную приборку,
типа такой Изображение
Баграунд сменить на тёмный, чуть приборы переделать и будет с твоими приборами схоже...имхо.
Сообщение #116 macarych » 26.03.2013, 20:50
Да это мне как-то в голову взбрело, попробовать сделать такую имитацию приборов в авто. Попробовал, сделал и успокоился. Попутно проверил на жизнеспособность vu meter с круговой шкалой, вполне жизнеспособен.
Сообщение #117 vladj » 26.03.2013, 21:08
Кстати твоя нейтрон лайт, желтенькая, очень в пору пришлась к одной из сборок, которую я пытался переделать, скрин выложу,
создав наверное тему, ибо там у меня крупная загвоздка получилась.
Сообщение #118 onv » 27.03.2013, 02:48
macarych:foo_vis_vumeter revue 2
:eek: Ты этим ужасом процы в лютые морозы прогреваешь ? :biggrin:
Для полного апофеоза осталось только добавить DRON-овскую скринсейверную примочку, чтобы вся эта братва дружно, но хаотично плавала по экрану ...
onv M
Сообщение #119 Cov » 27.03.2013, 03:58
К сожалению, это содержание малого и среднего бизнеса музыка не доступно в Германии, потому что Gema не предоставила соответствующие издательские права музыке.
К сожалению об этом.
Hmm :think:
Cov
Сообщение #120 macarych » 27.03.2013, 06:21
onv, ладно, признаюсь честно. Это я сделал для overclockers.ru, в раздел "Программы для тестирования процессоров семейства Core i3/i5/i7 (микроархитектура Sandy Bridge)" ;-)
Cov, вот вся конструкция, можешь скачать, запустить у себя и посмотреть.
foo_vis_vumeter revue.zip
