А как импортировать fcl-файл из командной строки? Я не нашел такой возможности:George Smith писал(а):Импортируйте fcl, но через cmd
Available switches:
/add <list-of-files> - appends the specified files to the current playlist instead of replacing the playlist content and playing them immediately
/immediate - suppresses the delay when adding files
/play, /pause, /playpause, /prev, /next, /rand, /stop - playback controls
/exit - exits foobar2000
/show, /hide - shows or hides the main foobar2000 window
/config - opens the Preferences dialog
/command:<menu command> - invokes the specified main menu command
/playlist_command:<context menu command> - invokes the specified context menu command on current playlist selection
/playing_command:<context menu command> - invokes the specified context menu command on currently played track
/context_command:<context menu command> <files> - invokes the specified context menu command on the specified files
$textbutton(40,0,50,20,WINSIZE,WINSIZE,windowsize:400:738,,)
Thanks a lotzeremy писал(а):foobar2000 /columnsui:import-quiet:<path>
