Скриншоты
Примечания
Список плагинов
Album list panel
ASIO support
Channel Spectrum panel
Columns UI
CUE fixer
Discogger
DR Meter
DSD Processor
DVD-Audio Decoder
ELPlaylist
EsPlaylist
Explorer Tree
Graphic Equalizer
HDCD decoder
Lyric Show Panel
Masstagger
MIDI Player
Multi-source lyrics
Panel Stack Splitter
Playback Statistics
Pretty Popup
Quick Search Toolbar
Run services
Skip Track
Spider Monkey Panel
Stop After Queue
Super Audio CD Decoder
Text Tools
vgmstream plugin
VST 2.4 adapter
VU Meter
Waveform seekbar
Дата сборки: 08.03.2025
Модифицировал: kutuzof
Версия плеера: 2.24.3 [x86]
История изменений: 08.03.2025
- fb2k v2.24.3 [x86]
21.02.2025
- fb2k v2.24.2 [x86]
14.01.2025
10.01.2025
04.01.2025
28.12.2024
21.12.2024
19.12.2024
17.12.2024
- fb2k v2.24.1 [x86]
29.11.2024
- fb2k v2.24 [x86]
21.09.2024
1. Обновление:
   - fb2k v2.1.6 [x86]
   - fb2k v1.6.18
   - fb2k v1.5.12
12.05.2024
- RADIO RECORD (MP3/320 kbps)
- другие мелкие исправления
03.05.2024
fb2k v2.1.5 [x86]
30.04.2024
23.04.2024
22.04.2024
- fb2k v2.1.4 [x86]
- плейлисты
Скриншоты
Сообщение #661 pinyuszka » 20.12.2024, 23:42
Hi kutuzof!
I really like your new 2.24.1 reference image!
The bottom left corner looks very nice with the foobar2000 caption!
The colors of the pause, play, stop control buttons in the bottom right corner look very nice!
youtube, spotify, wikipedia, etc buttons in the top right corner are active but unfortunately not visible.
All control button contours are more pronounced than on my interface.
How can I transfer these great head gestures to my interface?
Still the best foobar2000 interface is YOURS , keep it up!
pinyuszka
С нами: 3 года 3 месяца
Сообщение #662 kutuzof » 21.12.2024, 09:47
pinyuszka:How can I transfer these great head gestures to my interface?
The assembly is fully customizable, you just need to carefully read some points from the first message. If something is not clear, I will tell you.
Сообщение #663 pinyuszka » 21.12.2024, 17:00
Your point is well taken Kutuzof! I admit you spoiled us a bit with your quick and accurate answers ;)
Of the three points, 1 and 3 are fully met!
I have read point 2 but not everything is clear.
I could change the color of pause, play, stop buttons and it was easy.
I managed to activate the display of youtube, spotify, etc. buttons in the top right corner in the hidden menu, but it looks like it is displaying incorrectly (fonts installed in fonts folder)
I don't know how to change the contour of all control buttons.
I cannot display foobar2000 caption in bottom left corner.
pinyuszka
Сообщение #664 kutuzof » 21.12.2024, 18:08
pinyuszka:fonts installed in fonts folder
If you installed it, then the buttons should be displayed.
pinyuszka:I don't know how to change the contour of all control buttons.
I didn't do anything with the button outlines.
pinyuszka:I cannot display foobar2000 caption in bottom left corner.
In the notes (item 9) under the spoiler there is a diagram of the location of the hidden buttons. At the very bottom on the left are hidden buttons for customizing your text.
Сообщение #665 pinyuszka » 21.12.2024, 19:00
I did the font installation wrong!
I copied it manually from the foobar2000 fonts folder to the windows fonts folder, I didn't do it right.
I didn't know how to install it this way. I learned a lot from you today!
The hidden buttons in the lower left corner completely escaped my attention, but now it's clear.
How do I change the font size of the foobar2000 inscription in the lower left corner?
pinyuszka
Сообщение #666 kutuzof » 21.12.2024, 19:46
pinyuszka:How do I change the font size of the foobar2000 inscription in the lower left corner?
Сообщение #667 pinyuszka » 21.12.2024, 20:50
Thank you for your patient help!
I managed to set everything up as it is in your reference image.
One thing is still bothering me, the visibility of the button contours.
Maybe it's because of the scaling to 4K resolution, or something else, the edges of the buttons are almost invisible.
I asked earlier if it was possible to highlight the buttons somehow, but you wrote that it wasn't possible.
Anyway, it could make a perfect skin look even better.
This is just my subjective opinion.
pinyuszka
Сообщение #668 kutuzof » 21.12.2024, 22:08
pinyuszka:края кнопок почти не видны.
I don't have time or desire to deal with scripts from DarkOne4Mod v2.0 (for now). The only thing you can try is to make the buttons a little lighter.
Сообщение #669 Red » 22.12.2024, 00:44
kutuzof, Приветствую. помогите вернуть кнопку "Visual" :help:
Red
С нами: 5 лет 5 месяцев
Сообщение #670 kutuzof » 22.12.2024, 09:10
Red:помогите вернуть кнопку "Visual"
А Вы читали "Примечания" пункт 4. :wink:
Добавлено спустя 2 часа 22 минуты:
made the outline of the buttons 2 pixels
Replace JS and PSS scripts according to the screenshots:
JS.rar
Control Panel 2.txt
Сообщение #671 pinyuszka » 22.12.2024, 15:21
Kutuzof! Thank you very much for your effort!
It's true that the change is not big, but the contours are more defined!
She looks better after than before!
Before vs After: gif
pinyuszka
Сообщение #672 kutuzof » 25.12.2024, 19:49
pinyuszka, check your private messages
Сообщение #673 kutuzof » 28.12.2024, 16:15
pinyuszka, I updated the build (added buttons)
Сообщение #674 pinyuszka » 29.12.2024, 16:53
Kutozof!
Thank you for your hard work!
The highlighting of the buttons is perfect!
pinyuszka
Сообщение #675 slovak » 01.01.2025, 18:10
Hi Kutuzof, thanks for the great update, i got just a question, opening the skin i got the spider monkey message error:
Failed to process delayed packages. How to avoid that? Thank you.
slovak
С нами: 5 лет 3 месяца
Сообщение #676 krosh74 » 01.01.2025, 19:07
Здравствуйте ! Кто подскажет - постоянно выкакивает в фубаре вашей ( именно вашей ) сборки подтверждение сертификации .
krosh74 M
С нами: 4 месяца 17 дней
Сообщение #677 alex69722 » 01.01.2025, 23:00
Заблокируй исходящее подкл. exe файла (файл запуска) в брандмауэре. на радиостанции не знаю как повлияет я не пользуюсь. пробуйте. Добра и удачи.
alex69722
С нами: 1 год 1 месяц
Сообщение #678 krosh74 » 01.01.2025, 23:42
alex69722, Спасибо , но не помогло .Ранше эта сборка работала без проблемм (много лет ) . Решил поставить поновее , не зря говорят что если работает - не лезь . Другие сборки пробовал они без проблем .
krosh74 M
Сообщение #679 alex69722 » 02.01.2025, 08:13
Вы все правильно делаете ? из контекстного меню не работает. нужно заходить в сам брандмауэр создавать правило и т.д. указав путь к exe файлу запуска фубара. (в пути установки)
alex69722
Сообщение #680 kutuzof » 02.01.2025, 11:30
slovak:Failed to process delayed packages. How to avoid that?
Я не совсем вас понял, картинка бы не помешала. Если сломались пакеты биографии и библиотеки, то попробуйте загрузить их заново.
Biography-v1.4.2
Library-Tree-v2.4.0
