foobar2000 v1.5.0
Сообщение #1 VEG » 09.07.2019, 19:42
Вышла финальная версия foobar2000 v1.5.0! Предыдущая версия: foobar2000 v1.4.8.
  • New and improved Properties dialog, with the ability to manipulate attached pictures as well as scan and modify ReplayGain values.
  • Greatly improved Selection Properties performance for large track lists.
  • Various prompts (such as delete/recycle) now come with a “do not show this again” checkbox.
  • Restored pre-1.4 behavior of main-window-hidden/notification-icon-only status being remembered after foobar2000 restart.
  • Added logging of Media Library scanning errors - “show errors” button in Media Library Preferences.
  • Added Advanced Preferences option for flushing playback queue on manual track change (default: on).
  • Made “Open containing folder” command work with tracks in archives - opens folder containing the archive.
  • Added an option to preserve last-modified timestamps of tracks when updating tags.
  • Additional safeguards against corrupted configuration in case of a system crash while saving (FlushFileBuffers).
  • File Operations: delete/recycle prompt always says “Delete” rather than “Recycle”, since not every volume supports recycle action.
  • FFmpeg 3.4.6, now compiled with MS compiler, binary size reduced due to DLL runtime.
  • FLAC 1.3.3
  • Implemented reading of cue+bin audio CD images.
  • Implemented asynchronous drag&drop, for less stalls when dragging tracks from foobar2000 to another program.
  • Removed transacted filesystem support. There are no known benefits to it and even Microsoft documentation says not to use it.
  • Improved programming interfaces for External Tags and Skip Track components.
  • Made album art loading/resizing operations in Default User Interface asynchronous. Large pictures no longer make the app momentarily unresponsive.
  • Converter: Added Opus encoder selection for –music / –speech modes.
  • Converter: New list control in various dialogs. Column sizes are remembered.
  • Improved playback position reporting with Skip Silence and similar DSP effects.
  • Made possible to check for updates of components listed but not hosted on foobar2000.org.
  • Enabled embedded cuesheet support for MP3 files.
  • Made WavPack/DSD MD5 visible - using another field so Verifier doesn't try to verify it.
Автор темы, Администратор
Сообщение #21 VEG » 15.08.2019, 15:14
Beta 10
  • Various issues related to reporting exact playback position have been fixed. Wave seekbar style components show exact position with skip silence DSP active and similar.
  • Fixed Default UI Playlist View last column layout glitch regression.
  • Fixes in new programming interfaces for foo_external_tags.
  • Removed lyrics3 tag support other than removal via 'Remove Tags' - as it was causing more trouble than it was worth.
  • Default UI Album Art view regression fixes.
  • Cuesheet handling regression fixes.
  • DirectSound output workarounds for stuck playback on disconnected/locked device.
  • Properties dialog album art manipulation fixes.
  • Properties dialog autocomplete behaviors changed.
  • Fixed a bug causing certain components built using old foobar2000 SDK to fail to decode audio if certain new components are installed.
Сообщение #22 MeinHerz » 15.08.2019, 20:44
VEG:Beta 10
У кого-нибудь встроенный антивирус ругается? Скачивал с оффсайта, установить не смог. Там действительно троян или мелкие хотят, чтобы устанавливали из их недомагазина?
MeinHerz
С нами: 7 лет 2 месяца
Сообщение #23 SergPuh.68 » 16.08.2019, 11:40
MeinHerz, у меня всё нормально установилось,никто не ругался :smile:
С нами: 6 лет 6 месяцев
Сообщение #24 MeinHerz » 16.08.2019, 12:10
SergPuh.68:никто не ругался
Странно... Ругается именно на эту (десятую) бетку. Остальные без проблем. Посмотрю, что будет дальше. Так-то использую релиз (1.4.6).
MeinHerz
Сообщение #25 VEG » 16.08.2019, 13:39
MeinHerz, обычный false positive, частое явление (особенно для только что вышедшего софта). Знали бы на что опираются при принятии решений антивирусы, никогда не стали бы доверять им =)
Сообщение #26 VEG » 23.08.2019, 13:53
Beta 11
  • Fixed beta 10 regression causing File Integrity Verifier not to use multiple threads for scanning.
  • File size optimizations.
  • Library Preferences: fixed missing double-click-on-folder.
  • Support for latest External Tags component.
Сообщение #27 VEG » 06.09.2019, 18:40
Beta 12
  • Fixed preserve-file-timestamp bugs.
  • Fixed missing file-not-found error message.
  • Fixes for bad interaction between pre-1.4-SDK components and track info filters.
  • Fixed possible rare shutdown crash with certain components installed.
  • Playlist behavior fix.
  • Fixed metadb edit callbacks not being fired in some conditions.
  • Fixed track info filters (foo_external_tags) vs MP3 remove-tags.
  • Made track info filters (foo_external_tags) enabled by default once installed.
  • FLAC 1.3.3
  • New list control in various Converter dialogs.
Сообщение #28 Гармонист » 10.09.2019, 19:58
13 bata
]Prettier startup UI picker upon installation of a new UI component.
О каком новом интерфейсном компоненте идет речь? Кто нибудь его уже ставил?
Гармонист
Сообщение #29 Azaza » 11.09.2019, 01:32
Гармонист:О каком новом интерфейсном компоненте идет речь? Кто нибудь его уже ставил?
Речь идёт всего лишь о том, что раньше диалог выглядел так:
, а теперь выглядит так:
Сообщение #30 VEG » 11.09.2019, 12:09
Beta 13
  • Prettier startup UI picker upon installation of a new UI component.
  • Changed Properties dialog autocomplete behaviors
  • Attempted workaround for reported shutdown lockup
  • Changed order of FLAC metadata block to mitigate bugs in Windows 10
  • Fixed non-decoding of specific Ogg Vorbis files
  • Workaround for slow seeking in Matroska files.
Сообщение #31 postED » 12.09.2019, 22:52
Beta 14
  • Fixed beta 13 regression causing Verifier to incorrectly flag MP3 files as problematic.
С нами: 15 лет 7 месяцев
Сообщение #32 postED » 16.09.2019, 21:16
Beta 15
  • Fixed regressions in components updater dialog, manifesting themselves when you close & reopen the dialog.
  • Fixed bad behavior of properties dialog when cancelling initial info load.
Сообщение #33 VEG » 19.09.2019, 18:36
Beta 16
  • Fixed more regressions in components updater dialog.
  • Fixed missing keyboard shortcuts in new yes/no/ok/cancel type dialogs.
Сообщение #34 VEG » 07.10.2019, 14:50
Beta 17
  • The hopefully last beta.
  • Reverted DirectSound changes that seem to cause trouble for some users.
  • Improved playback position reporting accuracy with complex DSP configurations, for better operation of Wave Seekbar type components.
  • Made strange/malformed MP4 files not refuse to play entirely if the first audio frame can't be decoded.
  • List control behavior and screen reader compatibility fixes.
Сообщение #35 seriousstas » 08.10.2019, 10:38
Latest beta version
Download foobar2000 v1.5 beta 16
Что-то пошло не так)
Сообщение #36 VEG » 08.10.2019, 12:09
На HA ещё на проблемы жалуются, так что вероятно будет ещё одна бетка =)
Сообщение #37 LUR » 09.10.2019, 01:44
VEG:Beta 17
Сообщение #38 VEG » 12.10.2019, 01:25
Beta 18
  • Fixed beta 17 DirectSound crash regression.
  • Screen reader compatibility improvements.
Beta 19
  • Made preserve-file-timestamp work with MP3 tag types operations.
  • Fixed a long-time bug with erratic behavior of audio output device selection.
Сообщение #39 MrGrey » 24.10.2019, 09:29
foobar2000 v1.5 beta 20 has been released. Version 1.5 stable version will be out soon.
Beta 20
  • Fixed a regression causing incorrect playback time, or even incorrect playing track to be shown after changing DSP settings in mid-playback.
  • Made preserve-file-timestamp work with old album art manipulation context menu commands.
MrGrey M
С нами: 18 лет 9 месяцев
Сообщение #40 SergPuh.68 » 26.10.2019, 08:42
В этой версии хотелось бы иметь возможность включения/отключения полос прокрутки в компонентах где они присутствуют.
Вернуться в Новости плеера
