foobar2000 v2.0.0 (впервые нативная 64-битная версия)
Список разделов Аудиоплеер foobar2000 Новости плеера
Сообщение #1 VEG » 30.08.2022, 19:26
Вышла финальная версия foobar2000 v2.0.0! Предыдущая версия: foobar2000 v1.6.16.
  • Support for modern processor architectures. Now available as:
    • x86 32-bit (legacy) - requires Windows 7 or newer.
    • x86 64-bit - requires Windows 7 64-bit or newer.
      64-bit foobar2000 requires 64-bit builds of components; it can not load legacy 32-bit components. However, at this time, most components have 64-bit builds available already.
    • ARM - requires Windows 11 ARM device.
      foobar2000 for ARM has been compiled in Emulation Compatible (ARM64EC) mode and can load components built for x86 64-bit. There's no need for component developers to specifically build ARM components.
  • User interface updates:
    • Dark mode support on Windows 10 and 11. Add-on components need to be updated to utilize it.
    • Added album art in Default User Interface playlist view.
    • Clickable rating stars in Default User Interface playlist view (with new Playback Statistics component only).
    • New Default UI element: ReFacets, reimplementing most of Facets functionality. Old Facets component doesn't work with new 64-bit foobar2000.
    • Improved Default UI splitter, now allows any number of panes.
    • Added 'remember per playlist layout' to Default User Interface playlist view.
    • Added 'stream selector' element to Default User Interface toolbar.
    • Some Default UI Elements (ReFacets, Equalizer, visualisations) now also accessible as Columns UI panels.
    • Made more edit boxes recognize ctrl+backspace.
    • Fixed remembered main window position/size not respecting system DPI settings.
  • Configuration management changes:
    • New internal playlist format, changes instantly saved to disk, no more recent changes lost on crash.
    • New configuration data format, changes instantly saved to disk, no more recent changes lost on crash.
    • For non-portable installs, profile folder is now %appdata%\foobar2000-v2. There is no need to back up old profile before upgrading, your foobar2000 v1.x profile will be left untouched.
    • First run performs import of old configuration data (playlists, library).
    • New full config reset semantics - now clears profile folder (optionally leaving user-components intact) instead of asking all components to reset themselves.
  • DSP technology updates:
    • Made possible to apply DSP config changes without reinitializing affected DSPs.
    • Allowed DSPs to manipulate their shown name depending on preset data.
    • Added crossfeed DSP from foobar2000 mobile.
    • Added sample rate exclusions to SSRC resampler.
  • Audio codec technology updates:
    • More audio formats supported out of the box: TAK, APE, AC3, DTS.
    • Latest revision of APE format is supported (Monkey's Audio 10.09).
    • Updated WavPack to version 5.6.0.
    • Updated FFmpeg to version 6.0.
    • libvorbis is now used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
    • Cleaned up Ogg reader, made possible to seek in remote (HTTP etc) Ogg files.
    • Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
    • Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
    • Fixed bad MD5 verification of AIFF sourced WavPacks.
    • Added extra sanity checks to tag update operations in built-in codecs: made sure that attempts to remove covers from files that didn't have them in first place don't alter files at all.
  • Properties dialog updates:
    • Properties dialog now follows theme colors of the active UI.
    • Improved behavior if 'reload info' detects a change in number of chapters etc.
    • Updated Automatically Fill Values logic, better results if searched pattern appears more than once.
    • Logs tag update errors to console.
  • These add-on components are now obsolete as their functionality is available out of the box:
    • foo_benchmark
    • foo_bitcompare
    • foo_verifier
    • foo_input_monkey
    • foo_ac3
    • foo_sanitizer
    • foo_input_dts
  • These components previously included with the installer are no longer optional (features always enabled):
    • foo_rgscan
    • foo_cdda
    • foo_albumlist
  • Other:
    • Media Library efficiency improvements for very large music libraries.
    • New audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device.
    • Can display file creation time (%file_created%) and attributes (%file_attributes%).
    • Internet Radio dialog (File menu), remembers previously played Internet radio streams.
    • Modernized Explorer integration, no longer needs separate 32bit/64bit shell extension DLLs.
    • Utilized Windows Imaging Component for picture decoding, removed libwebp dependency. Album covers in HEIF, AVIF, etc can now be viewed if system codecs are present.
    • Added %year% mapping, takes year part of %date%, discarding content past first four digits.
    • Changed default Album List patterns to use %year%.
    • New console logging system, writes per-instance log files to the specified folder.
    • Fixed incorrect handling of M4A itunescompilation=0.
    • Fixed glitching when seeking with smooth playback and CPU-heavy DSPs active.
    • Converter: Pass float32 audio to LAME encoder.
    • Changed replacement for slash character in file naming.
    • Fixed audio glitching on screen resolution change in certain configurations.
    • Improved exclusive output behavior with uncommon channel layouts, 4.1/5.0 would not play on a device expecting 5.1-side.
    • Worked around ages old problem with external changes to file tags causing loss of foo_playcount data (needs new foo_playcount).
    • Preferences / Shell: changed default target playlist name.
    • Better console logging of internet radio stream reconnect events.
    • Worked around foo_input_dvda bugs, no longer crashes on null album art data returned.
    • Updated exclusive output device-specific workarounds.
    • Compiled with Visual Studio 2022.
Скачать: https://www.foobar2000.org/download
Автор темы, Администратор
С нами: 11 лет 1 месяц
Сообщение #101 derothist » 19.04.2023, 03:21
ManikManik2011, Windows XP давно не актуальная ОС, поэтому на совместимость с ней разработчикам софта тоже пофиг :smile:
derothist
С нами: 3 месяца 18 дней
Сообщение #102 VEG » 19.04.2023, 11:04
Ну в случае с foobar2000 это в первую очередь обусловлено переходом на использование WASAPI (для вывода звука по умолчанию), который поддерживается начиная с Windows Vista. Ну и сборка программы теперь осуществляется в VS2019-VS2022, которые не поддерживают сборку под XP. Для сборки под XP нужно использовать устаревший тулкит из VS2017.
Сообщение #103 audiolover80s » 19.04.2023, 12:45
ManikManik2011:Мне поф*г так как Foobar2000 1.5.11 последняя версия для Windows XP НУ ПОЧЕМУУУУУУУУУУ!!!!!!!!!!!!!!!!!!!!!!!!!
А как насчет винды-95, или 3.1 ???
audiolover80s M
С нами: 1 месяц 21 день
Сообщение #104 ManikManik2011 » 19.04.2023, 13:21
derothist:ManikManik2011, Windows XP давно не актуальная ОС, поэтому на совместимость с ней разработчикам софта тоже пофиг :smile:
Понятно тогда битву тысячелетия между аимпом и фубаром выиграл аимп! 5.11.2429 спокойно запускается! А для запуска 2.0.0 мне нужно весь ПК обновлять чтобы он не сгорел во время запуска семёрки
Добавлено спустя 5 минут 7 секунд:
VEG:Ну в случае с foobar2000 это в первую очередь обусловлено переходом на использование WASAPI (для вывода звука по умолчанию), который поддерживается начиная с Windows Vista. Ну и сборка программы теперь осуществляется в VS2019-VS2022, которые не поддерживают сборку под XP. Для сборки под XP нужно использовать устаревший тулкит из VS2017
Это обусловлено буржуйством разработчика и нежеланием продолжать делать плеер удобным для каждого пользователя ПК а также желанием продать плеер ответственным разработчикам и перестать бомбить с того что аимп существует.
Последний раз редактировалось VEG 19.04.2023, 22:44, всего редактировалось 1 раз.
Причина: Удалены оскорбительные высказывания
VEG » 19.04.2023, 22:45 Предупреждение на 30 дней
Хамство
ManikManik2011 M
С нами: 1 месяц 16 дней
Сообщение #105 VEG » 19.04.2023, 21:21
Beta 34
  • Release candidate build.
  • Fixed a timer manipulation issue that resulted in missing search query & autoplaylist refresh events when using time-based queries.
  • Fixed wrong scrollbar context menus in various places.
  • Fixed an internal regression that prevented Classic User Interface playlist from live-tracking title formatting configuration changes.
  • Added ctrl+del handling to various edit boxes.
Сообщение #106 derothist » 23.04.2023, 00:18
Уже 34-я бета :smile: Это рекорд, или были версии плеера с более "долгим" состоянием в бета?
derothist
Сообщение #107 VEG » 25.04.2023, 20:07
Beta 35
  • Better detection of non-dark-mode-supported systems. Dark mode features disabled on Windows 10 older than 1809.
  • Dark mode: fixed scroll bars in dropdown lists not being darkened.
  • Fixed startup lockup with certain library viewer configurations.
Добавлено спустя 5 минут 38 секунд:
derothist, ну как бы это наверное самый значимый апдейт со времени выхода версии 0.9, большое количество бет ожидаемо :wink:
Сообщение #108 MrGrey » 26.04.2023, 20:48
After a long testing cycle, foobar2000 v2.0 final has been released
MrGrey M
С нами: 16 лет 7 месяцев
Сообщение #109 Гармонист » 27.04.2023, 19:03
Поставил 2 версию 32 бит. Не работает перемещение вертикального разделителя разделов. Не работает добавление плейлистов в дерево плейлистов (плагин плейлист органайзер) методом драг+дроп. Откатился в старую версию. Все плейлисты исчезли. Одним словом не работает.
Гармонист
С нами: 9 лет 11 месяцев
Сообщение #110 NanoBot » 28.04.2023, 20:34
Выход релиза - это конечно замечательное событие! Но что у нас со звучанием финальной версии? У кого какие мнения на этот счет?
NanoBot
С нами: 2 месяца 27 дней
Сообщение #111 Azaza » 28.04.2023, 22:25
NanoBot:что у нас со звучанием финальной версии?
То же самое, что и со звучанием всех предыдущих версий.
С нами: 6 лет 8 месяцев
Сообщение #112 imfam » 30.04.2023, 17:38
Переход на версию foobar2000 v.2 x32 CUI прошёл достаточно безболезненно.
Пришлось убрать foo_facets, foo_out_wasapis и foo_out_asio+dsd, поставить foo_out_asio.
Выяснилось, что VOB не читаются вшитым декодером. Пришлось для VOB пока оставить в сборке foo_input_ffmpeg и внешний ffmpeg. Хотелось бы включить VOB в плеер в будущем.
Ещё есть пожелание исключить из ReFacets "Missing tag" для файлов, указанных в соответствующих CUE. Или даже вообще не показывать эти файлы в списке треков.
imfam M
С нами: 10 лет
Сообщение #113 mik » 30.04.2023, 18:46
Ну вот, опять началось. Win11 опять запрещает установку финальной версии foobar2000 v2.0.0.
mik
С нами: 7 лет 6 месяцев
Сообщение #114 derothist » 30.04.2023, 23:26
mik, у меня тоже Win 11, через права администратора и отключенным бестолковым Защитником всё нормально ставится. В меню предупреждения будет "Выполнить в любом случае (небезопасно)/Доверять непроверенному источнику
derothist
Сообщение #115 NanoBot » 03.05.2023, 19:21
Azaza:То же самое, что и со звучанием всех предыдущих версий.
А вот я услышал некоторые изменения, причем в лучшую сторону (за что очередной респект разработчикам). Ну да ладно, эта тема здесь почему-то непопулярна...
mik:Win11 опять запрещает установку финальной версии foobar2000 v2.0.0
Кстати, его (фубар) вообще не обязательно устанавливать в систему. Можно просто распаковать (программой 7Zip или аналогичной) содержимое инсталлятора в любую удобную папку и запускать foobar2000.exe (можно даже в разных папках держать сразу несколько версий).
NanoBot
Сообщение #116 Azaza » 04.05.2023, 18:28
NanoBot:Кстати, его (фубар) вообще не обязательно устанавливать в систему. Можно просто распаковать (программой 7Zip или аналогичной) содержимое инсталлятора в любую удобную папку и запускать foobar2000.exe (можно даже в разных папках держать сразу несколько версий).
В инсталляторе и так предусмотрена возможность установки в портативном режиме, распаковывать архиватором нет необходимости.
Сообщение #117 NanoBot » 05.05.2023, 17:48
Azaza:В инсталляторе и так предусмотрена возможность установки в портативном режиме, распаковывать архиватором нет необходимости.
Мы не ищем легких путей :smile:
NanoBot
Сообщение #118 main user » 07.05.2023, 12:39
Пардон за нубский вопрос.
В последних линейках появились в составе Фубара файлы .dll библиотеки, входящие в состав компонентов Microsoft Visual Studio (типа msvcp и vcruntime). А раньше, в версиях до 1.4 этих либов в составе программы не было. Почему?
Фубар всегда собирался с использованием Visual Studio или нет? Почему раньше они были не нужны?
main user
С нами: 4 месяца 8 дней
Сообщение #119 Azaza » 07.05.2023, 13:40
main user, потому, что до версии 1.4 использовалась статическая линковка библиотек, а с версии 1.4 - динамическая.
Сообщение #120 main user » 07.05.2023, 14:43
Azaza, статическая это как? И почему это перестало устраивать сейчас? Мне сказали, что библиотеки должны присутствовать в системе. Типа было предупреждение раньше.
У меня в системе их нет, только необходимый минимум. И Фубар прекрасно работает (имею в виду старые версии). Видимо я совсем не пользуюсь чем-то, для чего они предназначены. Или я не так все понимаю?..
main user
Вернуться в Новости плеера
