foobar2000 v2.0 (впервые нативная 64-битная версия)
Сообщение #1 VEG » 30.08.2022, 19:26
Вышел foobar2000 v2.0! Предыдущая версия: foobar2000 v1.6.17. Версия для Windows XP: foobar2000 v1.5.11.
  • Support for modern processor architectures. Now available as:
    • x86 32-bit (legacy) - requires Windows 7 or newer.
    • x86 64-bit - requires Windows 7 64-bit or newer.
      64-bit foobar2000 requires 64-bit builds of components; it can not load legacy 32-bit components. However, at this time, most components have 64-bit builds available already.
    • ARM - requires Windows 11 ARM device.
      foobar2000 for ARM has been compiled in Emulation Compatible (ARM64EC) mode and can load components built for x86 64-bit. There's no need for component developers to specifically build ARM components.
  • User interface updates:
    • Dark mode support on Windows 10 and 11. Add-on components need to be updated to utilize it.
    • Added album art in Default User Interface playlist view.
    • Clickable rating stars in Default User Interface playlist view (with new Playback Statistics component only).
    • New Default UI element: ReFacets, reimplementing most of Facets functionality. Old Facets component doesn't work with new 64-bit foobar2000.
    • Improved Default UI splitter, now allows any number of panes.
    • Added 'remember per playlist layout' to Default User Interface playlist view.
    • Added 'stream selector' element to Default User Interface toolbar.
    • Some Default UI Elements (ReFacets, Equalizer, visualisations) now also accessible as Columns UI panels.
    • Made more edit boxes recognize ctrl+backspace.
    • Fixed remembered main window position/size not respecting system DPI settings.
  • Configuration management changes:
    • New internal playlist format, changes instantly saved to disk, no more recent changes lost on crash.
    • New configuration data format, changes instantly saved to disk, no more recent changes lost on crash.
    • For non-portable installs, profile folder is now %appdata%\foobar2000-v2. There is no need to back up old profile before upgrading, your foobar2000 v1.x profile will be left untouched.
    • First run performs import of old configuration data (playlists, library).
    • New full config reset semantics - now clears profile folder (optionally leaving user-components intact) instead of asking all components to reset themselves.
  • DSP technology updates:
    • Made possible to apply DSP config changes without reinitializing affected DSPs.
    • Allowed DSPs to manipulate their shown name depending on preset data.
    • Added crossfeed DSP from foobar2000 mobile.
    • Added sample rate exclusions to SSRC resampler.
  • Audio codec technology updates:
    • More audio formats supported out of the box: TAK, APE, AC3, DTS.
    • Latest revision of APE format is supported (Monkey's Audio 10.09).
    • Updated WavPack to version 5.6.0.
    • Updated FFmpeg to version 6.0.
    • libvorbis is now used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
    • Cleaned up Ogg reader, made possible to seek in remote (HTTP etc) Ogg files.
    • Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
    • Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
    • Fixed bad MD5 verification of AIFF sourced WavPacks.
    • Added extra sanity checks to tag update operations in built-in codecs: made sure that attempts to remove covers from files that didn't have them in first place don't alter files at all.
  • Properties dialog updates:
    • Properties dialog now follows theme colors of the active UI.
    • Improved behavior if 'reload info' detects a change in number of chapters etc.
    • Updated Automatically Fill Values logic, better results if searched pattern appears more than once.
    • Logs tag update errors to console.
  • These add-on components are now obsolete as their functionality is available out of the box:
    • foo_benchmark
    • foo_bitcompare
    • foo_verifier
    • foo_input_monkey
    • foo_ac3
    • foo_sanitizer
    • foo_input_dts
  • These components previously included with the installer are no longer optional (features always enabled):
    • foo_rgscan
    • foo_cdda
    • foo_albumlist
  • Other:
    • Media Library efficiency improvements for very large music libraries.
    • New audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device.
    • Can display file creation time (%file_created%) and attributes (%file_attributes%).
    • Internet Radio dialog (File menu), remembers previously played Internet radio streams.
    • Modernized Explorer integration, no longer needs separate 32bit/64bit shell extension DLLs.
    • Utilized Windows Imaging Component for picture decoding, removed libwebp dependency. Album covers in HEIF, AVIF, etc can now be viewed if system codecs are present.
    • Added %year% mapping, takes year part of %date%, discarding content past first four digits.
    • Changed default Album List patterns to use %year%.
    • New console logging system, writes per-instance log files to the specified folder.
    • Fixed incorrect handling of M4A itunescompilation=0.
    • Fixed glitching when seeking with smooth playback and CPU-heavy DSPs active.
    • Converter: Pass float32 audio to LAME encoder.
    • Changed replacement for slash character in file naming.
    • Fixed audio glitching on screen resolution change in certain configurations.
    • Improved exclusive output behavior with uncommon channel layouts, 4.1/5.0 would not play on a device expecting 5.1-side.
    • Worked around ages old problem with external changes to file tags causing loss of foo_playcount data (needs new foo_playcount).
    • Preferences / Shell: changed default target playlist name.
    • Better console logging of internet radio stream reconnect events.
    • Worked around foo_input_dvda bugs, no longer crashes on null album art data returned.
    • Updated exclusive output device-specific workarounds.
    • Compiled with Visual Studio 2022.
Скачать: https://www.foobar2000.org/download
Автор темы, Администратор
Сообщение #181 VEG » 26.11.2023, 23:46
Qk3:Настолько высокомерный? :)
Нет, просто он один человек, который разрабатывает и поддерживает достаточно популярный плеер. Это считай вторая бесплатная работа. На то, чтобы отвечать на все сообщения, может просто не быть времени.
Добавлено спустя 5 минут 13 секунд:
В больших коммерческих проектах, как правило, у обычных пользователей вообще нет шансов пообщаться с разработчиками. Вы будете общаться со специально обученными отвечать на вопросы людьми или с роботом, а до разработчиков какие-то проблемы и жалобы дойдут только в случае если вам ну очень повезёт или кроме вас о такой же проблеме сообщают сотни других пользователей. Потому что время разработчика очень дорогое и ему надо продукт разрабатывать, а не пользователям на вопросы отвечать. В домашних проектах по сравнению с этим считай что индивидуальное обслуживание от разработчика, так как он как минимум сам ознакамливается с проблемами пользователей, а не получает 0.1% выжимку от службы поддержки.
Сообщение #182 Qk3 » 27.11.2023, 10:47
VEG:достаточно популярный плеер
В какой среде он популярный? Т.е. мне интересно под какую категорию слушателей он заточен. Интересуюсь потому, что слушать Фубар со встроенной звуковой картой невозможно, - (слышится) чисто студийный звук. Вероятно, при разработке проекта foobar2000 предполагались какте-то дополнительные корректирующие звучание приспособления?
VEG:На то, чтобы отвечать на все сообщения, может просто не быть времени.
Ну а почитать что-то про foobar2000 от автора, узнать что побудило автора создать foobar2000, где-то можно?
VEG:В больших коммерческих проектах, как правило, у обычных пользователей вообще нет шансов
Я бы так не сказал.. Было, однажды обращался в крупную китайскую фмрму к производтелям цифрового железа с проблемой софта.
Ответили быстро. Я даже был удивлен, таким быстрым реагированием. Проблема была решена.
Большое спасибо Гуглу за перевод текста!
VEG:Вы будете общаться со специально обученными
У автора бесплатного проекта есть специально обученные, aka служба поддержки? :) (юмор)
Зачем тогда Вы в качестве примера берете крупные коммерческие проекты?
Обычно, авторы бесплатных проектов рады обратной связи с потребителями.
VEG:ему надо продукт разрабатывать, а не пользователям на вопросы отвечать
Важно, и первое, и второе. Без обратной связи он может разрабатывать только что-то для себя. Я знаю авторов домашних проектов, не менее популярных, чем fobbar2000, которые очень активно общаются с потребителями, учитывают их замечания и пожелания. Ведь по сути потребители тестируют продукт, корректируют параметры, помогают его совершенствовать, чем развивают популярность.
VEG:индивидуальное обслуживание
Риторика. По сути пользователи обслуживают проект автора своим вниманием к его проекту. Своим временем, возможно, и донатами. Без обратной связи проект быстро станет никому ненужным.
Qk3
С нами: 6 лет 11 месяцев
Сообщение #183 VEG » 27.11.2023, 20:56
Qk3:В какой среде он популярный?
Среди энтузиастов по аудио =)
Qk3:Вероятно, при разработке проекта foobar2000 предполагались какте-то дополнительные корректирующие звучание приспособления?
Ну сколько можно транслировать этот бред.
Qk3:Я бы так не сказал..
А теперь попробуйте обратиться к Google с просьбой добавить какую-нибудь фишку в Android, например =)
Qk3:Было, однажды обращался в крупную китайскую фмрму к производтелям цифрового железа с проблемой софта.
Вы либо с поддержкой общались и вам помогли решить типовую проблему, либо же производитель настолько маленький и нишевый, что у него есть возможность и время пообщаться с каждым клиентом.
Qk3:У автора бесплатного проекта есть специально обученные, aka служба поддержки? :) (юмор)
Весь этот абзац был про крупные компании типа Google. Про то что там у вас есть возможность пообщаться максимум с поддержкой (и то не всегда, часто отвечают какие-то боты, которые не вникают в то что вы написали), а тут автор проекта сам как минимум прочитывает сообщения пользователей на его форуме.
Сообщение #184 Qk3 » 27.11.2023, 23:05
VEG, боьшое спасибо за ответы. Во многом с Вами согласен.
Qk3
Сообщение #185 Qk3 » 28.11.2023, 09:19
VEG:Среди энтузиастов по аудио =)
Энтузиастов цифрового аудио? Т.е. покупателей? :)
Qk3
Сообщение #186 VEG » 28.11.2023, 09:51
Qk3:Т.е. покупателей?
Покупателей чего?
Сообщение #187 Qk3 » 28.11.2023, 10:05
VEG:Покупателей чего?
Простите, не уточнил. В данном случае я имел ввиду покупателей цифрового аудио железа.
Qk3
Сообщение #188 VEG » 28.11.2023, 10:19
Ну нужно же на чём-то музыку слушать.
Сообщение #189 Qk3 » 28.11.2023, 12:10
Для музыки есть винил и бобинные магнитофоны.
Или энтузиасты уже пересели на прослушивание быстро сменяющихся семплов, с помощью компьютеров и софт-плееров, интерпретирующих подобие музыки? :)
Qk3
Сообщение #190 OlolOшник » 28.11.2023, 15:31
Qk3:Или энтузиасты уже пересели на прослушивание быстро сменяющихся семплов, с помощью компьютеров и софт-плееров
А что в этом, собственно, плохого? Это удобнее, практичнее, лучше по качеству - одни плюсы! :wink:
OlolOшник
С нами: 3 года 10 месяцев
Сообщение #191 Qk3 » 28.11.2023, 17:17
OlolOшник:А что в этом, собственно, плохого? Это удобнее, практичнее, лучше по качеству - одни плюсы!
Я не о том, что такое хорошо, и что плохо. Чисто в познавательных целях.
Каждый выбирает то, что ему нравится. Никто ничего никому не навязывает. Кому-то надо удобство, кому-то винил-ритуал.
Я хотел узнать о каких энтузиастах шла речь. Не более. Никакой критики.
Вот foobar2000, он под что заточен, под слушание музыки, или под показания приборов? На какую акустику ориентирован? Это очень важно.
Вопрос: о каком качестве Вы говорите? О способности без искажений воспроизводить 20 КГц (которые никто не слышит), или о динамическом диапазоне 6 дБ (DR6) с клиппингом +5 дБ (гиперболизировано)? Как по мне, то качество цифровых записей очень плохое, в сравнении, напр., с магнитной записью прошлых лет (до "войны громкостей"). Теоретически, да, у цифры огромный потенциал. Но на практике он не реализован. Что имеем, flac 24-bit, 192 KHz, DR 3-6? Где качество?
Qk3
Сообщение #192 Azaza » 28.11.2023, 18:41
Qk3, ты уже успел переслушать все цифровые записи с большим значением DR, существующие в мире? Или, хотя бы, все, доступные на рутрекере? Нет? Тогда не неси бред.
Сообщение #193 VEG » 28.11.2023, 19:45
Есть энтузиасты аналогового аудио, есть энтузиасты цифрового аудио. Это пересекающиеся, но разные множества. И совершенно очевидно, что foobar2000 для энтузиастов цифрового звука, которым не лень поддерживать свою библиотеку музыки, прописывать там теги, интересно посравнивать аудиокодеки и т.д. А обычные люди давно слушают музыку онлайн на Spotify или подобном, им вообще непонятно зачем музыку на компе хранить и думать там о каких-то кодеках =)
Добавлено спустя 2 минуты 46 секунд:
Но это конечно уже какой-то дикий оффтоп.
Сообщение #194 Qk3 » 28.11.2023, 23:46
Azaza:Qk3, ты уже успел переслушать все цифровые записи с большим значением DR, существующие в мире? Или, хотя бы, все, доступные на рутрекере? Нет? Тогда не неси бред.
И не собирался никогда. Скачал музыку, которая нравится, - DR никакой. Слушать не реально. Shift+Delete. Музыка убита. Смысл качать мертвечину?
Azaza:Тогда не неси бред.
Может качнем что-нибудь, посмотрим DR? :)
Вот, напр., это нормальный DR? > https://rutracker.org/forum/viewtopic.php?t=6173873 > Лог проверки качества
Почитайте комменты:
> https://rutracker.org/forum/viewtopic.php?p=83238738#83238738
> https://rutracker.org/forum/viewtopic.php?p=83239208#83239208
> https://rutracker.org/forum/viewtopic.php?p=83246432#83246432
Качнул. Красивая картинка получилась: > https://i.ibb.co/cX8g9nS/1.png :)
VEG:это конечно уже какой-то дикий оффтоп.
Согласен. Прекращаю. 1000 извинений.
Qk3
Сообщение #195 AleksBelg » 03.12.2023, 23:13
Подскажите пожалуйста. Какой плагин нужно добавить или сделать настройку, чтобы 64 битная версия фубара читала файлы формата *.dsf и *.dff (DSD)?
У меня при попытке воспроизвести файл пишет неизвестный формат.
AleksBelg
С нами: 1 год 6 месяцев
Сообщение #196 4foo » 04.12.2023, 12:15
AleksBelg:Какой плагин нужно добавить
https://sourceforge.net/projects/sacddecoder/files/foo_input_sacd/
4foo
С нами: 3 года 6 месяцев
Сообщение #197 AleksBelg » 05.12.2023, 22:15
4foo:https://sourceforge.net/projects/sacddecoder/files/foo_input_sacd/
Спасибо. Все получилось. Позвольте еще вопрос. У меня в "Album list" почему то не отображаются папки с альбомами в формате *.dsf и *.dff (DSD)?
Не могу понять почему.
AleksBelg
Сообщение #198 main user » 06.12.2023, 16:15
Когда же, Петя достреляется до нового финала? По опыту прежних обновительных сезонов это можно сказать? С мая уж...
Что его держит в бэте? Что не выходит?
И пилит-то, говорят, всё вокруг-да-около. Не плейера как такового приблуды. А типа радио... и иже с ним. :eek:
"Где имение, а где вода..." (с) Стругацкие
main user
С нами: 2 года 4 месяца
Сообщение #199 VEG » 06.12.2023, 17:00
Ну может решил делать релизы раз в год, чтобы не заморачиваться с частыми минорными обновлениями.
Поддержка радио вполне себе важная часть плеера.
Сообщение #200 main user » 06.12.2023, 18:14
Ну, тогда логичнее вообще отойти от таких терминов, как альфа, бэта, релиз...
Пили себе потихонечку..., ковыряйся, исправляй... Каков глубокий смысл в финалах? В любом случае, финал это никогда не финал. :smile:
Добавлено спустя 1 минуту 5 секунд:
Финал есть только у заброшенного софта. :biggrin:
main user
Вернуться в Новости плеера
