Список разделов › Сообщество › Сайт и форум
// [begin] Extended Quick Reply Form mod
$quote_link = '';
if ( $quick_reply )
$quote_link = '<br /><a href="javascriptquoteSelection(\'' . addslashes($poster) . '\')" onMouseOver="catchSelection()">' . $lang['QR_quote_link'] . '</a><br />';
$poster = '<a href="javascriptputName(\'' . addslashes($poster) . '\')">' . $poster . '</a>';
// [end] Extended Quick Reply Form mod
// bbCode control by
// subBlue design
// www.subBlue.com
// Startup variables
var imageTag = false;
var theSelection = false;
// Check for Browser & Platform for PC & IE specific bits
// More details from: http://www.mozilla.org/docs/web-developer/sniffer/browser_type.html
var clientPC = navigator.userAgent.toLowerCase(); // Get client info
var clientVer = parseInt(navigator.appVersion); // Get browser version
var is_ie = ((clientPC.indexOf("msie") != -1) && (clientPC.indexOf("opera") == -1));
var is_nav = ((clientPC.indexOf('mozilla')!=-1) && (clientPC.indexOf('spoofer')==-1)
&& (clientPC.indexOf('compatible') == -1) && (clientPC.indexOf('opera')==-1)
&& (clientPC.indexOf('webtv')==-1) && (clientPC.indexOf('hotjava')==-1));
var is_moz = 0;
var is_win = ((clientPC.indexOf("win")!=-1) || (clientPC.indexOf("16bit") != -1));
var is_mac = (clientPC.indexOf("mac")!=-1);
// Define the bbCode tags
bbcode = new Array();
bbtags = new Array('[b]','[/b]','[i]','[/i]','[u]','[/u]','[quote]','[/quote]','\[code\]','\[/code\]','[list]','[/list]','[list=]','[/list]','[img]','[/img]','[url]','[/url]');
imageTag = false;
// Replacement for arrayname.length property
function getarraysize(thearray) {
for (i = 0; i < thearray.length; i++) {
if ((thearray[i] == "undefined") || (thearray[i] == "") || (thearray[i] == null))
return i;
return thearray.length;
// Replacement for arrayname.push(value) not implemented in IE until version 5.5
// Appends element to the array
function arraypush(thearray,value) {
thearray[ getarraysize(thearray) ] = value;
// Replacement for arrayname.pop() not implemented in IE until version 5.5
// Removes and returns the last element of an array
function arraypop(thearray) {
thearraysize = getarraysize(thearray);
retval = thearray[thearraysize - 1];
delete thearray[thearraysize - 1];
return retval;
function checkForm() {
formErrors = false;
if (document.post.message.value.length < 2) {
formErrors = l_empty_message;
if (user_logged == 0) {
if (document.post.username.value == '' && !(formErrors)) {
formErrors = l_enter_your_name;
if (formErrors) {
alert(formErrors);
return false;
bbstyle(-1);
//formObj.preview.disabled = true;
//formObj.submit.disabled = true;
setTimeout("document.post.post.disabled = true; document.post.post.value = l_sending", 0);
return true;
function emoticon(text) {
var txtarea = document.post.message;
text = ' ' + text + ' ';
if (txtarea.createTextRange && txtarea.caretPos) {
var caretPos = txtarea.caretPos;
caretPos.text = caretPos.text.charAt(caretPos.text.length - 1) == ' ' ? caretPos.text + text + ' ' : caretPos.text + text;
txtarea.focus();
txtarea.value += text;
txtarea.focus();
function emoticon_wospaces(text) {
txtarea.focus();
txtarea.focus();
function bbstyle(bbnumber) {
txtarea.focus();
donotinsert = false;
bblast = 0;
if (bbnumber == -1) { // Close all open tags & default button names
while (bbcode[0]) {
butnumber = arraypop(bbcode) - 1;
txtarea.value += bbtags[butnumber + 1];
buttext = eval('document.post.addbbcode' + butnumber + '.value');
eval('document.post.addbbcode' + butnumber + '.value ="' + buttext.substr(0,(buttext.length - 1)) + '"');
imageTag = false; // All tags are closed including image tags :D
txtarea.focus();
return;
if ((clientVer >= 4) && is_ie && is_win)
theSelection = document.selection.createRange().text; // Get text selection
if (theSelection) {
// Add tags around selection
document.selection.createRange().text = bbtags[bbnumber] + theSelection + bbtags[bbnumber+1];
txtarea.focus();
theSelection = '';
return;
else if (txtarea.selectionEnd && (txtarea.selectionEnd - txtarea.selectionStart > 0))
mozWrap(txtarea, bbtags[bbnumber], bbtags[bbnumber+1]);
return;
// Find last occurance of an open tag the same as the one just clicked
for (i = 0; i < bbcode.length; i++) {
if (bbcode[i] == bbnumber+1) {
bblast = i;
donotinsert = true;
if (donotinsert) { // Close all open tags up to the one just clicked & default button names
while (bbcode[bblast]) {
imageTag = false;
txtarea.focus();
return;
} else { // Open tags
if (imageTag && (bbnumber != 14)) { // Close image tag before adding another
txtarea.value += bbtags[15];
lastValue = arraypop(bbcode) - 1; // Remove the close image tag from the list
document.post.addbbcode14.value = "Img"; // Return button back to normal state
imageTag = false;
// Open tag
txtarea.value += bbtags[bbnumber];
if ((bbnumber == 14) && (imageTag == false)) imageTag = 1; // Check to stop additional tags after an unclosed image tag
arraypush(bbcode,bbnumber+1);
eval('document.post.addbbcode'+bbnumber+'.value += "*"');
txtarea.focus();
return;
storeCaret(txtarea);
// From http://www.massless.org/mozedit/
function mozWrap(txtarea, open, close)
var selLength = txtarea.textLength;
var selStart = txtarea.selectionStart;
var selEnd = txtarea.selectionEnd;
if (selEnd == 1 || selEnd == 2)
selEnd = selLength;
var s1 = (txtarea.value).substring(0,selStart);
var s2 = (txtarea.value).substring(selStart, selEnd)
var s3 = (txtarea.value).substring(selEnd, selLength);
txtarea.value = s1 + open + s2 + close + s3;
return;
// Insert at Claret position. Code from
// http://www.faqts.com/knowledge_base/view.phtml/aid/1052/fid/130
function storeCaret(textEl) {
if (textEl.createTextRange) textEl.caretPos = document.selection.createRange().duplicate();
var selection = false; // Selection data
// Catching selection
function catchSelection()
if (window.getSelection)
selection = window.getSelection().toString();
else if (document.getSelection)
selection = document.getSelection();
else if (document.selection)
selection = document.selection.createRange().text;
// Putting username to the post box
function putName(name)
emoticon_wospaces('[b]'+name+'[/b]\n');
document.post.message.focus();
return;
// Putting selection to the post box
function quoteSelection(name)
if (selection)
emoticon_wospaces('[quote="'+name+'"]' + selection + '[/quote]\n');
selection = '';
return;
else
alert(l_no_text_selected);
return;
function bbfontstyle(bbopen, bbclose) {
if ((clientVer >= 4) && is_ie && is_win) {
if (!theSelection) {
txtarea.value += bbopen + bbclose;
txtarea.focus();
return;
document.selection.createRange().text = bbopen + theSelection + bbclose;
txtarea.focus();
return;
mozWrap(txtarea, bbopen, bbclose);
return;
else
txtarea.focus();
Спайк писал(а):Подкиньте пжста ява-скрипт быстрого цитирования выделенного текста, который корректно работает в любом браузере
а куда нужно нажать?РАБОТАЕТ!
где?Anatoly писал(а):Спайк писал(а):Подкиньте пжста ява-скрипт быстрого цитирования выделенного текста, который корректно работает в любом браузере
РАБОТАЕТ! ;)
