foobar2000 v1.5.6
Сообщение #1 VEG » 02.09.2020, 16:08
Вышла финальная версия foobar2000 v1.5.6! Предыдущая версия: foobar2000 v1.5.5. Эта версия поддерживает Windows XP.
  • Bug fix update with latest fixes from 1.6 series.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files.
  • Fixed ZIP reader memory leak.
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
  • Improved handling of last modification times in ZIP and RAR archives.
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
Скачать: https://www.foobar2000.org/old
Автор темы, Администратор
Вернуться в Новости плеера
