foobar2000 v2.0.0 (впервые нативная 64-битная версия)
Сообщение #1 VEG » 30.08.2022, 19:26
Вышла финальная версия foobar2000 v2.0.0! Предыдущая версия: foobar2000 v1.6.16.
  • Support for modern processor architectures. Now available as:
    • x86 32-bit (legacy) - requires Windows 7 or newer.
    • x86 64-bit - requires Windows 7 64-bit or newer.
      64-bit foobar2000 requires 64-bit builds of components; it can not load legacy 32-bit components. However, at this time, most components have 64-bit builds available already.
    • ARM - requires Windows 11 ARM device.
      foobar2000 for ARM has been compiled in Emulation Compatible (ARM64EC) mode and can load components built for x86 64-bit. There's no need for component developers to specifically build ARM components.
  • User interface updates:
    • Dark mode support on Windows 10 and 11. Add-on components need to be updated to utilize it.
    • Added album art in Default User Interface playlist view.
    • Clickable rating stars in Default User Interface playlist view (with new Playback Statistics component only).
    • New Default UI element: ReFacets, reimplementing most of Facets functionality. Old Facets component doesn't work with new 64-bit foobar2000.
    • Improved Default UI splitter, now allows any number of panes.
    • Added 'remember per playlist layout' to Default User Interface playlist view.
    • Added 'stream selector' element to Default User Interface toolbar.
    • Some Default UI Elements (ReFacets, Equalizer, visualisations) now also accessible as Columns UI panels.
    • Made more edit boxes recognize ctrl+backspace.
    • Fixed remembered main window position/size not respecting system DPI settings.
  • Configuration management changes:
    • New internal playlist format, changes instantly saved to disk, no more recent changes lost on crash.
    • New configuration data format, changes instantly saved to disk, no more recent changes lost on crash.
    • For non-portable installs, profile folder is now %appdata%\foobar2000-v2. There is no need to back up old profile before upgrading, your foobar2000 v1.x profile will be left untouched.
    • First run performs import of old configuration data (playlists, library).
    • New full config reset semantics - now clears profile folder (optionally leaving user-components intact) instead of asking all components to reset themselves.
  • DSP technology updates:
    • Made possible to apply DSP config changes without reinitializing affected DSPs.
    • Allowed DSPs to manipulate their shown name depending on preset data.
    • Added crossfeed DSP from foobar2000 mobile.
    • Added sample rate exclusions to SSRC resampler.
  • Audio codec technology updates:
    • More audio formats supported out of the box: TAK, APE, AC3, DTS.
    • Latest revision of APE format is supported (Monkey's Audio 10.09).
    • Updated WavPack to version 5.6.0.
    • Updated FFmpeg to version 6.0.
    • libvorbis is now used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
    • Cleaned up Ogg reader, made possible to seek in remote (HTTP etc) Ogg files.
    • Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
    • Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
    • Fixed bad MD5 verification of AIFF sourced WavPacks.
    • Added extra sanity checks to tag update operations in built-in codecs: made sure that attempts to remove covers from files that didn't have them in first place don't alter files at all.
  • Properties dialog updates:
    • Properties dialog now follows theme colors of the active UI.
    • Improved behavior if 'reload info' detects a change in number of chapters etc.
    • Updated Automatically Fill Values logic, better results if searched pattern appears more than once.
    • Logs tag update errors to console.
  • These add-on components are now obsolete as their functionality is available out of the box:
    • foo_benchmark
    • foo_bitcompare
    • foo_verifier
    • foo_input_monkey
    • foo_ac3
    • foo_sanitizer
    • foo_input_dts
  • These components previously included with the installer are no longer optional (features always enabled):
    • foo_rgscan
    • foo_cdda
    • foo_albumlist
  • Other:
    • Media Library efficiency improvements for very large music libraries.
    • New audio output device management features - unwanted devices can be disabled, bit depth and DSP can be configured per-device.
    • Can display file creation time (%file_created%) and attributes (%file_attributes%).
    • Internet Radio dialog (File menu), remembers previously played Internet radio streams.
    • Modernized Explorer integration, no longer needs separate 32bit/64bit shell extension DLLs.
    • Utilized Windows Imaging Component for picture decoding, removed libwebp dependency. Album covers in HEIF, AVIF, etc can now be viewed if system codecs are present.
    • Added %year% mapping, takes year part of %date%, discarding content past first four digits.
    • Changed default Album List patterns to use %year%.
    • New console logging system, writes per-instance log files to the specified folder.
    • Fixed incorrect handling of M4A itunescompilation=0.
    • Fixed glitching when seeking with smooth playback and CPU-heavy DSPs active.
    • Converter: Pass float32 audio to LAME encoder.
    • Changed replacement for slash character in file naming.
    • Fixed audio glitching on screen resolution change in certain configurations.
    • Improved exclusive output behavior with uncommon channel layouts, 4.1/5.0 would not play on a device expecting 5.1-side.
    • Worked around ages old problem with external changes to file tags causing loss of foo_playcount data (needs new foo_playcount).
    • Preferences / Shell: changed default target playlist name.
    • Better console logging of internet radio stream reconnect events.
    • Worked around foo_input_dvda bugs, no longer crashes on null album art data returned.
    • Updated exclusive output device-specific workarounds.
    • Compiled with Visual Studio 2022.
Скачать: https://www.foobar2000.org/download
Автор темы, Администратор
Сообщение #141 Azaza » 01.07.2023, 12:51
Фубар сам по себе не может вызывать BSOD. Могут кривые драйвера, кривая ОС, с которыми он взаимодействует при работе.
С нами: 7 лет
Сообщение #142 Palmir » 01.07.2023, 13:43
Azaza:Могут кривые драйвера, кривая ОС, с которыми он взаимодействует при работе.
При использовании foobar2000 x86 такой проблемы нет.
У меня BSOD отсутствует - при проигрывании внезапно перезагружается.
Использую чистую версию foobar2000 x64 v2.0 - не сборку.
В качестве компонентов - ASIO4ALL v2.15, foo_out_asio+dsd-0.3.6, foo_input_sacd-1.5.4.
Palmir
С нами: 2 месяца 20 дней
Сообщение #143 Azaza » 01.07.2023, 13:52
Palmir, попробуйте без foo_out_asio+dsd и вообще выводить не через ASIO.
С нами: 7 лет
Сообщение #144 main user » 17.07.2023, 01:05
Такой нубский вопрос, где брать 64-битные плагины к Фубару? Вот сайт - https://www.foobar2000.org/components
И где помечено, что компонент 64-битный? Не могу увидеть...
main user
С нами: 7 месяцев 24 дня
Сообщение #145 Azaza » 17.07.2023, 02:01
main user:где помечено, что компонент 64-битный? Не могу увидеть...
С нами: 7 лет
Сообщение #146 main user » 17.07.2023, 09:18
Azaza, чтобы это узнать, надо тыкать каждый компонент и открывать его? :eek:
А сколько там всего компонентов (основных плюс сторонних)?!
Добавлено спустя 2 минуты 10 секунд:
Подсказали на др. форуме. https://foobar2000.xrea.jp/index.php?更新状況
Что-то подобное я и имел в виду. Чтобы было как-то указано на превьюшках названий.
Отцы Фубара почему-то не додумались.
main user
Сообщение #147 mik » 09.08.2023, 15:45
Столкнулся с такой проблемой: при переходе на следующий трек альбома (flac 44.1/16) появляется "рык" на 2-3 секунды. Бессистемно. То есть, то нет. Альбомы хорошо знакомы и ранее такого не было. Перекопал всё что мог в настройках. Буфер и тд... asio "родной" и беспроблемный.
С какой версии началось, не могу сказать.
Несколько раз подобный "рык" появлялся в середине трека, непрекращающийся и foobar зависал.
ps Думаю нет смысла говорить, что на громкости+ , это вводит в стресс. Особенно в наушниках.
Честно говоря, начал подумывать о возвращении на 32bits, на которой ничего подобного не было.
mik
С нами: 7 лет 10 месяцев
Сообщение #148 Azaza » 09.08.2023, 18:35
mik, для начала попробовать существенно (вплоть до максимума) увеличить буфер File>Preferences->Playback->Output->Buffer length
В настройках ASIO тоже увеличить буфер, если есть такая настройка.
Попробовать WASAPI вместо ASIO.
mik:asio "родной" и беспроблемный
Откуда такая уверенность, что беспроблемный?
С нами: 7 лет
Сообщение #149 mik » 09.08.2023, 20:03
Поставил выход на "динамики (exclusive)". Вроде работает, даже 44.1/32bits.
"Откуда такая уверенность, что беспроблемный?"
Так при всех сценариях работал как часики ))
"динамики (exclusive)" это и есть новый WASAPI?
Надо ли ставить галку здесь для (exclusive) ?
mik
Сообщение #150 Azaza » 09.08.2023, 20:17
mik:"динамики (exclusive)" это и есть новый WASAPI?
Да.
mik:Надо ли ставить галку здесь для (exclusive) ?
Если и так работает нормально, то нет.
С нами: 7 лет
Сообщение #151 mik » 09.08.2023, 21:20
"Если и так работает нормально, то нет."
Работало, но только 24bits и не проходили 32bits. Поставил галку, и 32bits заработало. Оставлю))
ps Нашел здесь. (Exclusive output overrides=on, Use event=off in Advanced menu)
https://hydrogenaud.io/index.php/topic,122847.525 ... bit perfect (16bit, not 24bit)
mik
Сообщение #152 mik » 10.08.2023, 15:47
Оставил галку нa "event", в моём случае звучит лучше. Чуть больше вч = пошире сцена.
Вроде бы больше не "рычит". Понаблюдаю.
ps ( WASAPI exclusive существует два режима буферизации — Event и Push. Первый режим является технически более совершенным и лучше совместим с USB устройствами. Однако, режим event поддерживается не всеми звуковыми картами. Таким образом, предпочтительным является режим event. Если же воспроизведение в нем работать отказывается, необходимо переключиться на режим push.)
mik
Сообщение #153 VEG » 11.08.2023, 11:28
mik:Оставил галку нa "event", в моём случае звучит лучше. Чуть больше вч = пошире сцена.
Вам кажется. В звуке между ними разницы не будет. Разница только в том, как плеер определяет, когда нужно закинуть ещё декодированного звука в буфер. Допустим, буфер у нас на 100мс. При event драйвер аудиокарты периодически просит очередную порцию звуковых данных, когда он уже воспроизвёл, например, 70% от буфера (что значит примерно раз в 70мс). При push плеер сам просыпается каждые, например, 70мс, и закидывает очередную порцию звуковых данных в буфер. Больше ничего при этом не меняется, разница только в том, что в одном случае плеер периодически просыпается по запросу драйвера через событие (event), в другом случае плеер просыпается сам по таймеру (что помогает в случае, если драйвер кривой, и не умеет вовремя просить очередную порцию данных).
Сообщение #154 mik » 11.08.2023, 11:40
Согласен. В аудио, всё на уровне "показалось". Только двойной слепой тест (с учётом всех параметров) и замеры могут что-то обьективно показать.
Но, мне субьективно так показалось ))
mik
Сообщение #155 NanoBot » 18.08.2023, 14:19
mik, Если результат теста (даже не слепого) повторяется, то Вам не показалось. Я так же слышу разницу между разными вариантами настройки плеера (так же, как и между разными его сборками). Она есть и это не результат самовнушения, как тут пытаются все объяснить теоретики. Что касается объяснения данного явления, то уже есть отдельные попытки. Например, вот эта статья автора известного плеера Audirvana.
NanoBot
С нами: 6 месяцев 13 дней
Сообщение #156 Azaza » 18.08.2023, 19:51
NanoBot:Я так же слышу разницу между разными вариантами настройки плеера
Между какими именно вариантами настройки?
NanoBot:Что касается объяснения данного явления, то уже есть отдельные попытки. Например, вот эта статья автора известного плеера Audirvana.
В статье всего лишь рассказывается о том, что микшер ОС может изменять аудиоданные и о том, что величина джиттера может увеличиваться при увеличении загруженности системы. Такие явления, действительно, имеют место быть. Но никаких данных, по которым можно было бы сделать вывод о том, что это заметно на слух, в статье нет. И даже нет никаких данных, свидетельствующих о том, что плеер Audirvana позволяет добиться уменьшения величины джиттера. Лишь фантазии автора.
С нами: 7 лет
Сообщение #157 NanoBot » 18.08.2023, 21:37
Azaza:Между какими именно вариантами настройки?
Практически между всеми, имеющими отношение к воспроизведению звука.
NanoBot
Вернуться в Новости плеера
