Проблемы в Linux
Сообщение #1 joly-joly » 27.10.2024, 12:02
Установил на Linux. Всё хорошо работает, единственно рейтинг вместо звездочек отображается квадратиками. Может кто знает, как исправить?
Выхлоп терминала на всякий случай приведу.
 ~  wine foobar2000.exe  ✔
0120:err:winediag:gnutls_process_attach failed to load libgnutls, no support for encryption
0120:err:winediag:process_attach failed to load libgnutls, no support for pfx import/export
0120:err:winediag:process_attach Failed to load libgnutls, secure connections will not be available.
0120:err:secur32:SECUR32_initSchannelSP no schannel support, expect problems
0120:fixme:msvcrt:_set_abort_behavior _WRITE_CALL_REPORTFAULT unhandled
0058:fixme:mountmgr:query_property Unsupported property 0x7
0120:fixme:file:NtLockFile I/O completion on lock not implemented yet
0120:fixme:uxtheme:SetPreferredAppMode 3: stub
0120:fixme:win:SetWindowCompositionAttribute (00010062, 0087FBC0): stub
0120:fixme:uxtheme:AllowDarkModeForWindow 0001006E 0: stub
0120:fixme:uxtheme:AllowDarkModeForWindow 000D0084 0: stub
0120:fixme:uxtheme:AllowDarkModeForWindow 00010086 0: stub
0120:fixme:uxtheme:AllowDarkModeForWindow 00120082 0: stub
0120:fixme:uxtheme:AllowDarkModeForWindow 00010088 0: stub
0120:fixme:uxtheme:AllowDarkModeForWindow 0001009E 0: stub
0120:fixme:win:SetGestureConfig handle 0001009E, reserved 0, count 1, config 0087EFC8, size 12 stub!
0120:fixme:uxtheme:AllowDarkModeForWindow 000100A8 0: stub
0120:fixme:win:SetGestureConfig handle 000100A8, reserved 0, count 1, config 0087EF90, size 12 stub!
0120:fixme:uxtheme:AllowDarkModeForWindow 000100B8 0: stub
0120:fixme:uxtheme:AllowDarkModeForWindow 000100BC 0: stub
0120:fixme:win:SetGestureConfig handle 000100BC, reserved 0, count 1, config 0087F068, size 12 stub!
0130:fixme:kernelbase:AppPolicyGetThreadInitializationType FFFFFFFA, 02A6FF18
0120:fixme:winsock:setsockopt Unknown IPPROTO_TCP optname 0x00000005
0120:fixme:msvcrt:_SetWinRTOutOfMemoryExceptionCallback (784B8760): stub
0120:fixme:combase:RoGetActivationFactory (L"Windows.Media.Playback.BackgroundMediaPlayer", {00000035-0000-0000-c000-000000000046}, 0087FAFC): semi-stub
0120:err:combase:RoGetActivationFactory Failed to find library for L"Windows.Media.Playback.BackgroundMediaPlayer"
0120:fixme:combase:GetRestrictedErrorInfo (0087FAD4)
0120:fixme:combase:RoOriginateError 0x80040154, L"": stub
0140:fixme:wincodecs:jpeg_decoder_get_metadata_blocks stub
0140:fixme:gdiplus:resample_bitmap_pixel Unimplemented interpolation 7
А так, на первый взгляд, не хватает какого-то шрифта.
Вторая проблема. На винде я фубар с темой Georgia-ReBORN использую https://github.com/TT-ReBORN/Georgia-ReBORN/. На Linux не удалось с этой темой запустить. Пустое белое окно при запуске. Может и это кто знает?
Последний раз редактировалось joly-joly 27.10.2024, 17:16, всего редактировалось 1 раз.
joly-joly
С нами: 2 года 8 месяцев
Сообщение #2 VEG » 27.10.2024, 12:31
joly-joly:А так, на первый взгляд, не хватает какого-то шрифта.
Так и есть, не хватает шрифта с поддержкой нужного символа Unicode. Либо установите в настройках показ оценки с использованием другого символа, либо смотрите как установить шрифты с полной поддержкой Unicode (можете их прям из Windows и скопировать).
С нами: 12 лет 9 месяцев
Сообщение #3 joly-joly » 27.10.2024, 19:26
VEG, натолкнули на правильную мысль. Нашел, где в настройках меняется шрифт плейлиста, поменял на другой и всё стало, как надо.
joly-joly
