foobar2000 v2.25 preview
Сообщение #1 VEG » 10.05.2025, 01:51
Вышел foobar2000 v2.25! Предыдущая версия: foobar2000 v2.24.
  • Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
    • Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
    • foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
  • FFmpeg updated to 7.1, added native support for xHE-AAC decoding.
  • Media Library can natively index FTP/WebDAV/SMB network shares.
  • Added preferences page for network share credentials so you don't have to place them in URLs anymore.
  • Made editing DSP settings momentarily lower output latency to make DSPs appear more responsive.
  • Portable install: Changed the way relative paths are handled, so cached tags are no longer forgotten after relaunching from a different path.
  • Allowed = character in tag field names. Will be converted to _ in formats that don't allow =.
  • Installer is now hi-DPI friendly.
  • Rewritten Ogg FLAC tag handling, properly implemented embedded album art.
  • Made system file dialogs invoked out-of-process, to avoid stability issues.
Скачать: https://www.foobar2000.org/download
Автор темы, Администратор
С нами: 13 лет
Сообщение #2 VEG » 12.05.2025, 21:05
2025-05-12
  • Fixed unintended capture of ctrl+shift+left/right by tab containers.
  • Internet radio album art lookup regression fix.
  • Amended handling of dynamic info (live bitrate etc), the behavior in previous build was causing OpenMPT visualization to malfunction.
  • Monkey's Audio updated to 11.10.
С нами: 13 лет
Сообщение #3 VEG » 14.05.2025, 21:01
2025-05-14
  • Made live playback info manipulation match behaviors of old foobar2000 versions better, should fix Internet radio issues.
  • Windows: Removed dotted lines from various treeviews, refreshed Album List tree looks.
  • Windows: Fixed bad import of relative library paths when upgrading from portable install of old version.
  • Windows: More verbose output on "open containing folder" errors.
С нами: 13 лет
Сообщение #4 VEG » 19.05.2025, 22:01
2025-05-19
  • Mac: Fixed keyboard shortcuts page glitches.
  • Mac: Handle forward delete key in properties, playlist, etc.
  • Windows: Fixed "save all playlists" crash.
  • Windows: Various bug fixes in dark mode listview substitution code.
  • Windows: New VC runtime.
  • Windows: Made converter properly resolve redirected relative paths.
С нами: 13 лет
Сообщение #5 VEG » 20.05.2025, 22:32
2025-05-20
  • FFmpeg 7.1 updated to 7.1.1, fixed xHE-AAC bugs.
  • Windows: Fixed wrong default folder in Quick Convert in portable installs.
С нами: 13 лет
Сообщение #6 VEG » Вчера, 21:17
2025-05-22
  • Fixed playing track info possibly becoming out of sync when using seekbar near track switch.
  • Windows: Fixed initial directory not being set correctly in folder picker regression.
С нами: 13 лет
Вернуться в Новости плеера
