теги не редактируются!
Список разделов Другое Архив
Описание: Архив старых тем.
Сообщение #1 XPiS » 17.07.2007, 23:24
что за байда? Пишу в редакторе тегов что-нить, жму save и нифига!
CPU: Intel(R) Celeron(R) M processor        1.60GHz [x86 Family 6 Model 13 Stepping 8]
Operating System: Microsoft Windows XP [version: 5.1.2600 S]
Installed RAM: 895 MBytes
Free disk space on foobar2000 partition: 2101 MBytes
foobar2000 path: D:\Tools\Media\foobar2000\
Core version: foobar2000 v0.9.4.3
Build time: 22:36:33 on 20 April 2007
Active components (23):
foo_alarm.dll 1.05 [23 August 2006] - Alarm
foo_uie_albumart.dll 0.2.6 [16 January 2007] - Album Art Panel
foo_uie_albumlist.dll 0.2.1 [22 November 2006] - Album list panel
foo_albumlist_autoupdate.dll 0.2 [09 October 2006] - Albumlist autoupdate
foo_cdda.dll 2.1.1 [20 April 2007] - CD Audio Decoder
foo_cleartype.dll 0.2 [24 October 2006] - Cleartype font support
foo_ui_columns.dll 0.1.3 beta 1v7 [22 November 2006] - Columns UI
foo_version.dll 0.4 [02 May 2007] - Components versions viewer
foo_dsp_continuator.dll 0.4.1 [11 April 2007] - Continuator
foo_uie_vis_egoh.dll 1.1.2 [12 March 2007] - Egoh Spectrum analyser (uie)
foo_input_std.dll 1.1.0 [20 April 2007] - FLAC Decoder
foo_shutdown.dll 0.9 [01 June 2006] - Foo Shutdown
foo_masstag.dll 1.6 [20 April 2007] - Masstagger
foo_minimize_on_close.dll 0.2 [18 October 2006] - Minimize On Close
foo_osd.dll 1.52 [26 January 2007] - On-Screen Display GDI+
foo_playcount.dll 1.3.2 [16 September 2006] - Playback Statistics
foo_uie_quicksearch.dll 2.8k [03 January 2007] - Quick Search Toolbar
foo_infobox.dll 2.0.4 [09 October 2006] - Special file info box
foo_dsp_std.dll 1.0 [20 January 2007] - Standard DSP array
foo_input_std.dll 1.0 [20 April 2007] - Standard Input Array
foo_uie_tabs.dll 0.2.5 [17 October 2006] - Tabbed panel modified
foo_uie_trackinfo_mod.dll 0.8.0 beta [Jan  5 2007 - 13:36:12] [05 January 2007] - Track info panel mod
foo_input_std.dll 1.1 [20 April 2007] - WMA Decoder
XPiS
Сообщение #2 Sma11erM1nd » 17.07.2007, 23:42
А тэги случайно не WMA?
Sma11erM1nd M
Сообщение #3 XPiS » 18.07.2007, 02:00
м-да. Файл был ридонли. А никто не сказал %)
Последний раз редактировалось XPiS 18.07.2007, 02:16, всего редактировалось 1 раз.
XPiS
Сообщение #4 Sma11erM1nd » 18.07.2007, 03:26
неее просто у меня после обновсления моего фубара он не записывал тэги в WMA))))
Sma11erM1nd M
Сообщение #5 maxuser » 28.07.2007, 00:53
Кстати, вопрос из той же темы: как пофиксить длину воспроизведения у DTS файла? Реально там ок. 40 минут, а определяется только 5 :(
maxuser
С нами: 18 лет 10 месяцев
Сообщение #6 mgz » 28.07.2007, 05:26
2maxuser
Попробуй так: поменяй расширение на WAV и запусти. Должно всё шипеть (не играть), но длина должна отображаться как есть. Если окажется, что в WAV всё правильно со временем - значит глючит DTS плагин. А иначе - файл испорчен.
P.S.: Данный трюк (определение времени) прокатывает только в файлах DTS с параметрами 44100 Hz, 16 bit - т.е. которые были Audio DTS CD.
Последний раз редактировалось mgz 28.07.2007, 05:32, всего редактировалось 1 раз.
